Marine Lubrication >
Marine Lubrication
Marine Lubrication
Old 04-13-2009 | 06:17 PM
  #1571
Originally Posted by Racerngr1
I just called teague and he said the 50wt was too thick for the ocean and Havasu. They are only selling the kendall 40wt and that's what he would recommend for my engine. I think I'mgoing to run the WCF.
Too thick when, at operating temps?
I don't think so.
Is this the same shop that said not to use synthetic oil because it causes the rollers to slide and cause flat spots? And the starts recommending Amsoil because they are sponsored by them?
People, think for yourselves.
Ken
minxguy is offline
Old 04-13-2009 | 06:53 PM
  #1572
Hydrocruiser's Avatar
Arrow
Originally Posted by 07DominatorSS
Yeah, that will work too.
It really depends on the engine,...an 1100 HP super charged engine that considerably dilutes oill with gasoline would do well with a 50-60wt conventional/syn oil.
An HP 525 would be better off with a 40wt is you don't want a multi-vis...
Careful jumping to conclusions..
Hydrocruiser is offline
Old 04-13-2009 | 06:59 PM
  #1573
Hydro, I don't jump to conclusions. A 40 weight will work just fine, and so will the 50 weight in his engine. Personally, I would run the 15w-50 Racing Oil. Boats are under extreme stress and high temperatures, therefore, I would run the 50 weight. Especially in Havasu, with the temps out there, I would want the extra protection, but as stated earlier the 40 weight will work just fine.
07DominatorSS is offline
Old 04-14-2009 | 02:07 PM
  #1574
Arrow
I know you don't jump to conclusions..I was referring to Teague
I like double ester products best these days....oils like Motul 300V and Redline.
M-1 V-twin is great as well and SilverCap M-1 is a great oil (though POA) the price is 1/2 of a 2x ester oil.
Teague is just a rare bird is all...
Old 04-14-2009 | 02:42 PM
  #1575
I go boating alot and will put 20 hours on a boat in about a month so next time I change my oil, maybe I will try 50wt.
Racerngr1 is offline
Old 04-14-2009 | 04:13 PM
  #1576
Arrow
50 wt is best for temps 50*F up.
40 wt if less than 50*F.
Unless the engine is blown or has a very high lift cam use 40wt.
Old 04-14-2009 | 04:21 PM
  #1577
Run a 20w-50. It flows better when cold than a straight 50 and thins less at temps over (say 225 for sake of discussion) than a straight 50.
Ken
minxguy is offline
Old 04-14-2009 | 07:41 PM
  #1578
Arrow
Ken
FYI Ken...
I talked with the guys at Sterling a little bit ago. They like M-1 SilverCap with 20hr changes for the most part.
More is overkill and less is not wise I think was their thinking...most engines there go out the door with M-1 in the sump....
Old 04-15-2009 | 06:22 AM
  #1579
FYI Ken...
Make a choice on the side of caution. What is wrong with that?
OK, you may spend a few more bucks for oil, buy less beer.
Mobil is tough product to beat in any flavor. It is available everywhere, it is not all that expensive, although a lot of people on this board think so, and most important, it works and works very well. (I am not a fan of light viscosities ie 10w30 in boats.)
Add a change interval of 20 hours and the high zinc stuff (V-Twin) is waaaay overkill, but your are talking engines that are $25K and up.
Ken
minxguy is offline
Old 04-15-2009 | 06:57 AM
  #1580
525 mercs, what would you guys use...I currently use the Valvoline 20-50w VR-1 racing oil....With changes every 15-25 hours...Give me some suggetions or is there something better out there for better protection..Florida boating...
joefitness123 is offline
