Marine Lubrication
#1691
Rage,
A few things that are going to pertain specifically to you Is the 4 ball wear test, Kinematic Viscosity at 100*C, and the Viscosity Index. The Kinematic Viscosity at 212*F is going to give you a good idea as to the thickness between the pison/rings and cylinder walls. Basically on this test, the higher the number the better. The Amsoil MCV is 20.56, the Amsoil RD50 is 17.5, and the Mobil 1 V-Twin is 21.04. The Viscosity Index is going to help you make a good determination of how well the oil is going to maintain viscosity at high temperatures. The Amsoil MCV is 156, the Amsoil RD50 is 162, and the Mobil 1 V-Twin is 145. The other thing that I would note is the 4 Ball wear test. The 4 ball wear test is a good indication of how well the oil is going to protect your internal parts from wear. The Amsoil MCV is .373, the RD50 is .47, and the Mobil 1 V-Twin is .395. Basically the Mobil 1 is a very solid oil, but in your case since it’s harder for you to find, you might want to consider switching to the MCV as that’s a solid performer. Depending on how much reading you want to do, here are some fun facts for you.
http://www.amsoil.com/lit/G-2156.pdf
#1692
Hey minxguy, Did you get my PM?
Bill
[QUOTE=minxguy;2921079]
Bill
#1693
Lots of good info here. I am running merc 25w-40 now. Will i see more or less oil pressure with m-1 15w-50 gold cap hot and cold?? Also have the option of runing chevron delo 400 straight 40wt. oil. what would be your choice???
02 496ho's 180 hours
#1694
You're comparing apples to grapes. The Mobil 1 is a full synthetic and the dello is a dino oil. I would run Mobil over the dello oil. Oil pressure shouldn't change much, it might go up a little bit with the thicker stuff then your engine was designed for. My 500 EFI wants to run the 25/40, which is why I run this, which is still a 40 wt.
https://www.amsoil.com/storefront/wcf.aspx
#1695
Ken
#1696
-Now a 40wt being less viscous than a 50wt will run cooler as a heavier oil actually causes more friction.
-A rule of thumb is to use the lowest viscosity possible.
-Having said that....these engines are stressed to the max...a synthetic 25W-50 or 15w-50 ought be fine.
Amsoil's 15W-40 Marine is great too!
#1697
thanks again, jeff
#1698
I should explain why i compared these oils. I know one is syn. and one is not. The reason i asked about these was more for the viscosity. I can get through work (for free-part of my benefits package) m-1 15w-50 gold cap, delo 15w-40 or delo straight 40w hd . my main question is what weight would you run in stock 496ho's. the only reason i am not using merc 25w-40 is because these oils are not costing me anything and i think merc oil is $23.00 a gallon now and we can not buy it through our supplier at work. I am also running wix 51060 filters with no issues so far. also what amsoil drive oil do you recommend, the 75w-90 marine gear lube or the servere duty oil. My boating climate is 50 degrees or warmer(northern cheaspeake bay)
thanks again, jeff
thanks again, jeff
#1699
thanks again, jeff
thanks again, jeff
#1700
Ken,
Did you get my PM to you with my Email address?
Is there a problem with sending the two noted oil analysis?
I am definately still interested.
Bill
Bill
