Marine Lubrication
#1781
I have been using it in a Harley road glide 103. They are mechanically loud motor. It much quieter. Also run it in the trans and primary. Clutch feels better and shifts awesome. No more big clunk
#1782
I like the green, it is a nice indicator if there is a leak...seeing that power steering, trim, and tabs have same colored fluid.
#1783
Yes, they have. Rotella was one of the last hold outs to change. But they got forced to. It is still a real good oil, but it is not what it used to be. Same thing with Delo.
#1784
You guys put entirely to much time and energy into what oil to use and who's is best. I've never had an engine failure do to oil. The most important thing about oil is you change it. The richer the motor is the more often it needs changed. If you don't have a motor that is set in kill mode and dumping fuel into it to make it live you can make it a season without an oil change. 100 times more important than what brand oil is going in the motor is what oil filter is going to be used. If you collapse a filter your done. And due to the design of some filters they just don't flow any oil and become a huge restriction in the system which usually leads to a collapsed filter, empty wallet and a wife that tells you to get rid of the dumb thing.
Hint: $2/qt 20/50 oil works just as well as $10/qt 20/50 oil in motors that aren't being fuel diluted to stay alive.
#1785
Any thoughts on this particular filter? I usually use Wix but moved up to the HP6 size and this is what I found most easily available. I'm mostly concerned with the media being able to handle the typical moisture found in boats. Also using Brad Penn 10/40 in the ZZ502 motor.
#1786
Ken
#1787
#1788
$5.45 a quart: http://amzn.com/B00DJ4FIPQ
Sometimes Oreilly's and Advanced has it cheaper.
Still waiting for someone to prove or even think lubrication issues using this.
Valvoline VR-1 racing motor oils are recommended for engines burring gasoline and full or partial alcohol fuels in track and street service
Use in any car, light truck, van or SUV where API SN is recommended
ZDDP additive provides tough anti-wear protection
Enhanced with friction modifier to improve horsepower
Formulated with enhanced anti-foam system
#1790
