Marine Lubrication >
Marine Lubrication
Marine Lubrication
Old 10-13-2006 | 09:00 PM
  #851
Hydrocruiser's Avatar
Arrow Re: Marine Lubrication
Originally Posted by Rebel_Heart
I found some Spectro Golden 4 for $7/qt. Does that seem about right? Anything else in this price range that I should be considering? Thanks. This oil is a synthetic blend. Is this as good as the Mobil v-twin 20-50?
Mobil 20W-50 V-Twin is the worlds best 20W-50 Fully Synthetic Oil as it can handle more heat before flashing into flame than any other oil.
It's additive package is the best around.
Nothing but nothing beats this product for gasoline engines.
Anything else is #2.
Hydrocruiser is offline
Old 10-13-2006 | 10:23 PM
  #852
Default Re: Marine Lubrication
Is there such thing as mobil's 20W-50 and not being the v-twin formula?
cloudmaster_321 is offline
Old 10-14-2006 | 01:17 AM
  #853
Rebel_Heart's Avatar
Mixguy chooses Spectro Golden 4 as his oil of choice which is a blend. While Mobil 15w-50 and Mobil v-twin 20w-50 are synthetics. I am looking for an oil to change to after my break in oil (Valvoline 40). With a pair of 540s, how would you rank the above mentioned oils for my application? I am not looking to buy the most expensive oil, unless the others will not provide the needed protection. Thanks.
I found Mobil 15w-50 at $7 and v-twin 20w-50 at $9.
Rebel_Heart is offline
Old 10-14-2006 | 09:31 AM
  #854
I just saw the mobil 15W-50 for $28 for the 5-quart jug, and 6.46 a quart at Walmart........
Old 10-14-2006 | 10:42 AM
  #855
It's the only fully synthetic 20w50 Mobil makes. The labeling is for marketing purposes. It is a "4-cycle engine oil".
Old 10-14-2006 | 10:43 AM
  #856
My WallLand will take an order and get you as many 5 quart jugs as you want.
Old 10-14-2006 | 01:17 PM
  #857
GOTCHA, i ended up going with the Mobil 15W-30 and the mobile 302 filter
Old 10-14-2006 | 02:19 PM
  #858
I just contacted the local Wal-Mart and they have the same deal with the Mobil 1 15w-50. Not a bad price $28. Is this better to use than the Spectro Golden 4 or about the same qualities?
Old 10-14-2006 | 07:37 PM
  #859
Spectro Platinum Fully Synthetic PAO IV is equal I would say.
Spectro Golden 4 Blend is not nearly as good as M-1.
Old 10-15-2006 | 09:23 AM
  #860
Don't forget about these 2 strong oils:
http://www.modernoils.com/Series_2000_20w50.html
http://www.modernoils.com/MCV_20W50.html
Also look at this test. It is about motorcycle oils but still provides good info about a couple of the oils in this discussion.
http://www.modernoils.com/media/pdf_...Comparison.pdf
o2man98 is offline
