Merc motor mounts >
Merc motor mounts
Merc motor mounts
Old 07-18-2005 | 08:41 AM
Dave M's Avatar
Veteran: Navy
Default Merc motor mounts
I had my engine installed a few months ago. After the install I checked to see if the tabs were locked down. It appeared that they were. Last week I noticed that the port side mount dropped down about 1.5 inch. The top nut did not move so I lifted the engine and tightened the bottom nut back up. I didn't see any rubber shavings in the coupler area. I ran for about 10 hours, no problem. Yesterday I noticed the star. mount moved down about 1/4 inch. I pulled the drive and the alignment tool goes right in.
Is there a way to tell if any damage occured to the coupler? Maybe grab the snout and see if there is any play? Is there a way to make sure they don't move again?
Dave M is offline
Old 07-18-2005 | 09:14 AM
Default Re: Merc motor mounts
Tab washer mounts above bottom nut. It is meant to grab a flat from bottom nut and another tab is bent around the block mount, so bottom nut can't move.
If nuts move easily, get new ones; nylon section can become too worn to retain itself. Also, original mounts have a small strip of reusable locktite on stud. This may have disappeared or not been adequate to begin with.
Make sure tab washers are UNDER motor portion of mounts, above lower nuts.
I would bend tabs free at lower nuts.
Run lower nuts down to allow BLUE locktite to be added to studs.
Run nuts back to correct postion using alignment tool.
Bend tab onto nearby nut flat, and another tab around motor bracket of mount.
Like this.
http://www.mercruiserparts.com/Show_...NGINE+MOUNTING
Stingray69 is offline
Old 07-18-2005 | 10:16 AM
Sydwayz's Avatar
Forum Regulator
One of the other guys on the Donzi problem thread a few weeks ago mentioned putting hose clamps around the mounting bolts as spacers/relievers.
Sydwayz is offline
Old 07-18-2005 | 10:45 AM
Metal shavings are a pretty good indication of coupler damage. Did you see any when you pulled the drive off?
Gary Anderson is offline
Old 07-18-2005 | 11:25 AM
Dave M's Avatar
Veteran: Navy
I didn't see metal or rubber shavings. I didn't see any blue locktite on my mounts either. Is that something that the shop doing the install applies? The mounts are brand new with the engine. I'm hoping that I caught it in time or just got lucky and the coupler didn't get hosed up.
Dave M is offline
Old 07-18-2005 | 01:00 PM
Don't sweat the coupler. Just make sure you grease it often with the blue synthetic slpine grease; Merc or Sierra. Says for u-joints, too. Marine grease for gimbel bearing and hinge joints/upper pivot shaft.
Blue loctite is what YOU should apply. It will just make the nuts more resistant to loosening.
So, is the tab washer in the correct place? And is one tab bent to the motor mount?
Old 07-18-2005 | 02:40 PM
RedDog382's Avatar
Look inside the coupler from the transom with the drive removed. The face of the teeth on the inside where it contacts the spline should each have a small flat surface. When a coupler is worn, the flat spots on the teeth will become sharp points facing the center of the hole. This is caused by misalignment and lack of lubrication.
RedDog382 is offline
Nordicflame
Wanted
9
11-13-2008 12:59 AM
johnnyboatman
Wanted
5
09-20-2008 12:16 PM
98itrwhite
Wanted
6
04-27-2008 09:33 AM
superwrench0166
Detailing, Painting, & Fiberglass
0
07-24-2005 05:22 PM
convincor
Checkmate
50
07-11-2003 08:53 PM
