Mercruiser ECM connector >
Old 07-21-2005 | 06:55 AM
Daniel
Default Mercruiser ECM connector
I'm looking for ECM 32Pin connectors for the
Mercuiser AC Delco MEFI1 ECM. Has anybody a source
for such connectors?
Old 07-21-2005 | 07:12 AM
GOODT's Avatar
Default Re: Mercruiser ECM connector
MERCURY MARINE, I SOULD BE ABLE TO GET IT FOR YOU,
CALL ME OR EMAIL ME AT [email protected]
JOE
AMERICAN PERFORMANCE MARINE
APMBOATS.COM
GOODT is offline
Old 07-21-2005 | 09:54 AM
Mbam's Avatar
Offshoreonly Advertiser
I think I have a harness I can shake loose, will that help?
Mbam is offline
Old 07-22-2005 | 03:28 AM
Daniel
Thanks you all, I would like to remove the Mercruiser ECM
and connect an self programming aftermarket ECM. For this
project, I need connectors for adapting the aftermarket ECM
to the Mercruiser ECM wiring.
I need male connectors to connect on the female side of the
Mercruiser wiring.
Old 07-22-2005 | 06:27 AM
Mbam's Avatar
Daniel, you are most likely not going to find that. Easier to use the harness made for your ECM (replace the Merc ECM harness)
Mbam is offline
Old 07-23-2005 | 06:50 PM
Strip Poker 388's Avatar
Rob
Mark at Precision Marine has someone that makes them up for him. Give him a call and see. mark 504-469-7463
Rob
Strip Poker 388 is offline
C_Spray
01-07-2008 01:16 PM
5PMSMWHR
6
05-31-2007 11:33 PM
INDY27
3
08-13-2006 06:13 PM
captiainclark
3
12-07-2005 12:13 PM
jesper
2
09-26-2005 02:45 PM
