Customer put his battery in backwards... >
Old 07-21-2005 | 10:17 AM
imboating's Avatar
Veteran: Coast Guard
Racer
Default Customer put his battery in backwards...
Merc. HP500EFI, now it will not trigger the relays for the alarms or fuel pump. I've checked every fuse, breaker and connection. I've hooked up a scan tool and it can read the computer at all. I can only assume at this point the ECM Module has been damaged? Mercury can no longer get the part and only offers a replacement module plus an adapter kit, roughly $3000.00, wtf. Anyone have any ideas where I might find a replacement or a solution for this probelm?
Thanks, Rob.
More Adrenaline Please!!!
BoatRacingExperience.com
imboating is offline
Old 07-21-2005 | 10:59 AM
pachangalpina's Avatar
Default Re: Customer put his battery in backwards...
Check with Arizona Speed and Marine, TMP or Crockett. I am sure that there are others that can reprogram these computers also. The computers should be available from GM but will need to be programed. I would suggest that you just get the computer where you get the programming done. Be careful with ebay computers because they may be in the same condition as yours.
pachangalpina is offline
Old 07-21-2005 | 11:11 AM
I think, but am not sure, that there may be a fusible
link down near the starter.
Pesky Varmint
Pesky Varmint is offline
Old 07-23-2005 | 06:58 PM
Strip Poker 388's Avatar
Rob
I have heard when you do this . the ECM is fried
the 500efi ecm its going to be tuff finding one
Good luck
Rob
Strip Poker 388 is offline
Old 07-23-2005 | 07:00 PM
Rob
Mark at Precision Marine has converted then over to a differant computer . He also has the adaptor harness
Call mark at 504-469-7463
Rob
Old 07-24-2005 | 09:01 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Yep! I fried 1 of my ECM's this winter troubleshooting my engine alarm buzzer. Accidently ran 12v back to the ECM thru the alarm ground wire. Fuel pump relay started clicking like it was sending morse code, then stopped! Bought a used ECM from the board and sent it to Mark at Percision to have it reflashed to my motor specs. Call Mark, he just might be able to set you up. Used ECM's average right around $350 when I was looking, then couple more presidents to reflash.
US1 Fountain is offline
Hot Knots
Super Boat International
0
10-28-2008 05:46 PM
HPJunkie
3
03-10-2003 08:19 AM
