Whipple, Yes or No? >
Whipple, Yes or No?
Whipple, Yes or No?
Old 07-26-2005 | 06:47 AM
Perfectmix's Avatar
Default Re: Whipple, Yes or No?
TomCat..Do you have any cutomers with this system on a PQ 380? There isn't a whole lot of room in the engine compartment. I wish it was like other 38's where you can camp in the engine compartment. Those are impressive speed gains on the 35 lightning.
Perfectmix is offline
Old 07-27-2005 | 01:21 AM
Kama I have a 35 fountain lightning ts with modified hp 500 efi motors, bravo 1 32 pitch props rotating out. 90.7 mph/gps
bobd is offline
Old 07-27-2005 | 06:58 AM
when rtech was having tuning done on that efi combo at PRECISION that engine was screaming!! mark pounded on it for days , no failures.
if you insist on a whipple , good luck , they are no longer availble at this time to the best of my knowlage , there is a pair of quad carbed engines in the classified section by old school..
open87 is offline
Old 07-27-2005 | 07:36 AM
Smitty's Avatar
Whipples are having a backorder problem. They should be available soon. Call Whipple direct and ask for Dustin. Tell him you're from OSO. Call 559-442-1261
Smitty is offline
Old 07-27-2005 | 08:49 AM
Perfectmix: No one has done a boat like yours to my knowledge, but here is a picture of an installation in a Baja 250 (procharger conversion). If your seat backs are high like this, you may be able to fit the box under the top of the seat even if the seat is pushed back a lot. You need to get a tape measure in there.
open72: Mark is a thorough guy. We actually ended up with less HP after the tuning because we agreed it was safer to increase the fuel and reduce the timing a bit. 800 HP is quite enough on a production block. Rev limiter was set at 5600 RPM.
tomcat is offline
Old 07-27-2005 | 07:20 PM
i know , i was there
open87 is offline
Old 07-28-2005 | 08:09 AM
Perfectmix's Avatar
OPEN72--Not insistant on anything yet. Just weighing options right now. OldSchool's twin SC set up belongs right where it's at, in his CIG. My 38 PQ non-step is most likely never going to set any speed records, I'm just looking for a little more reliable pep. The Rtech looks and sounds like a nice set-up but room in the engine compartment is somewhat of an issue.
The engines are coming out this winter regardless, It would be a shame to reinstall bone stock
Adrenaline Junkie
Eliminator
16
07-02-2007 10:15 AM
25chkmate
11
06-22-2007 09:17 PM
JLS
0
03-25-2005 07:49 PM
EWB
0
08-05-2004 06:52 AM
aero-offshore
1
03-20-2004 12:35 PM
