Supercharging Hp525efi??????? >
Old 08-04-2005 | 04:10 PM
Default Supercharging Hp525efi???????
Has anybody had any luck supercharging the 525? I understand from a few people that they wont stay together even with moderate boost (5psi). And if so where are you getting them, I understand Whipple doesn't have any in stock and Procharger does not have one developed yet. I am at 6000' above sea level and I need some help! Thanks
MAGIC525 is offline
Old 08-04-2005 | 10:06 PM
Default Re: Supercharging Hp525efi???????
The stories you are hearing may be from the 496 and its cast pistons. The 525EFI is an excellent engine. We have supercharged it's little brother to 800 HP @ 7psi with good luck.We have a similar kit for the 525 that includes a relocated and much bigger closed cooling exchanger and reservoir, a must with this much HP. The main hold up has been the aftermarket's inability to crack the PCM 555 computer. We do have a solution though and it does not involve putting a distributor back in the engine. This setup will be going on the dyno for programming in September. If you call me I'll put your name on the list for the results.
tomcat is offline
Old 08-04-2005 | 10:13 PM
Pwrbt33's Avatar
Talking Re: Supercharging Hp525efi???????
Looks like a nice setup. I would be interested in seeing better pics and hearing about how it works out.
John
Pwrbt33 is offline
Old 08-05-2005 | 08:41 AM
Nordicflame's Avatar
Sounds like another high altitude, hp deprived member
It can be very frusterating to loose the kind of power we high altitude guys lose. I have found ways around it but it's expensive. Where are you located?
Tom, I need some dyno info. My guy is chomping at the bit to add one of your setups to my old motor in his boat if we could see some good results.
It's just never fast enough is it
Later,
Dave
Nordicflame is offline
Old 08-05-2005 | 01:04 PM
gsmith9898's Avatar
i HAVE BEEN WAITING FOR WHIPPLE. THEY TOLD ME OCTOBER. WHAT IS YOUR PLAN AND A PHONE NUMBER TO CALL FOR WAITING LIST?
gsmith9898 is offline
Old 11-14-2005 | 03:34 PM
gsmith9898's Avatar
what were the results?
intouch1
Drives and Lower Units
10
04-20-2008 07:34 PM
masher44
7
10-11-2004 12:27 PM
Wardey
08-20-2003 09:43 AM
kcgbjc
06-09-2003 06:29 PM
Mark in So. MD
08-17-2002 09:14 PM
