-   -   Tabs leaking water in bilge (https://www.offshoreonly.com/forums/general-q/109585-tabs-leaking-water-bilge.html)
REBEL4845 08-08-2005 06:18 PM
I have a 1988 boat. It has never been in the water for more than a weekend. The tab on the port side was dripping water into the bilge through the mounting bolts. I tightened them up and clear water sqeezed out of the bolt holes. Transom did not feel spongy at all. Should I worry??
Scott 08-08-2005 06:52 PM
Re: Tabs leaking water in bilge
Yes! Take them off and make sure the holes are dry If water "squeezed" out you know the answer. If you are lucky and the transom holes are dry re-install the bolts with lots of 3M 4200.
Best of Luck
REBEL4845 08-08-2005 06:55 PM
Best of Luck
And if the transom holes arnt dry? Thanks for the 3M #
Bad Girl 08-08-2005 08:52 PM
an '88 with water = rotten transom.
