MEFI-3 or MEFI-4? >
MEFI-3 or MEFI-4?
MEFI-3 or MEFI-4?
Old 08-10-2005 | 05:47 PM
Strip Poker 388's Avatar
Rob
Default Re: MEFI-3 or MEFI-4?
Originally Posted by outdrive man
i am a mercury dealer, get the serial numbers off your engines call your mercury dealer and he can get you mefi 4 update kits. or he can get you mefi 3 remans if still avalible. the reason they did away with mefi 3 is because gm wouldn`t make them anymore
There telling me when you order a 3 your get a 4 with a adapter harness.There going to be outrages for merc.
They have already started putting the 4's on the procharger and whipple set up.It should not be hard to find a stock map.
If ya find a 3 its going to have to be remapped anyway.
There is also 2 different #3's
Ck with Mark at Precision Marine in La 504-469-7463 his is having the harness made for them also.
Rob
Strip Poker 388 is offline
Old 08-10-2005 | 06:57 PM
I'm pretty sure I have at least a couple of mefi 3's and can flash them for whatever stock program you need. $500 each including the old ones as trade in. Contact me at [email protected] if you'd like.
RichardCranium572 is offline
Old 08-10-2005 | 07:16 PM
I called Mark today to discuss this. He said that he should be able to help but he believed that there was a slight software difference between the outdrive model and inboard model. I also called a Mercury dealer like cobra marty and outdrive man said and he gave me the MEFI-4 update kit part numbers for these engines. I assume the updated ECM's will have the proper maps already flashed into them. The only question now is at what price?
maghag is offline
Old 10-03-2005 | 12:33 PM
Maghag, Did you ever sort out your ECU problem? Is there a physical difference between the MEFI3 and the MEFI4? Do you still have your bad MEFI3 boxes? I might be interested. Thanks, Marty.
cobra marty is offline
Old 10-03-2005 | 11:02 PM
outdrive man's Avatar
No External Physical Differance Just The J-1 And J-2 Connectors Are Pinned Differently. More Than A few hundred Per Kit Is Highway Robery Merc Reman Sells These Kits Very Cheap as far as boat parts go
outdrive man is offline
Old 10-04-2005 | 05:51 AM
Are the J1 and J2 connectors the same? How many pin are they?
Old 10-05-2005 | 07:10 AM
ttt
Old 06-03-2011 | 10:27 AM
talked to Mark today at Precision Marine and was very impressed with his advice and honesty! Make sure to check them out!!
2KOOLPerformance is offline
scarab74
0
03-19-2007 05:13 PM
ls1nova
6
01-16-2007 09:25 PM
poolshrk
Fountain
3
08-27-2004 03:21 PM
poolshrk
0
08-24-2004 10:23 PM
