Drive Trim Actuator For Merc. Indicator >
Old 08-10-2005 | 08:40 PM
Elite Marine's Avatar
Default Drive Trim Actuator For Merc. Indicator
I have the single Mercruiser indicator for the Drive and Tabs. The actuator for the drive is a Blue Water Actuator which is an external rod that attaches to the drive ram. The problem is that it reads the opposite of what I need, when the ram extends (drive up) the indicators shows the drive going down. What are others runnig on their 28s with this type of indicator? I was told by Blue Water to change the cable to the top of the indicator, there is no room to do this.
Anyone?
Elite Marine is offline
Old 08-10-2005 | 10:07 PM
'05 Concept SF23
Default Re: Drive Trim Actuator For Merc. Indicator
I think the Stainless Marine indicator drive attachment is opposite. Joe Murray
f311fr1 is offline
Old 08-11-2005 | 02:34 AM
GOODT's Avatar
I belive the only thing that you can do is change the face on the indicator display...so the up is down and down is up, This is because the indicator just mimics the rams actions and there is no way for it to show reverse action. the face is avalible from mercury racing either that or you have to change it from bottom entry to top entry, your choice...if you click on the pic below you will see what i mean and can check for the part number that you need
GOODT is offline
Old 08-11-2005 | 05:47 AM
The problem with changing the indicator is that the drive and tabs are on the same indicator. I'll take pictures later today.
Thanks for the input.
Old 08-11-2005 | 06:21 AM
GOODT's Avatar
THATS OK, MERC MAKES THE ONES FOR THAT
GOODT is offline
Old 08-11-2005 | 05:38 PM
Joe -
I appreciate your info, I'm running a single though!!!
Also, the actuator I have doesn't give full indicator throw, it actually doesn't seem to work real well at all.
Now what?
Old 08-12-2005 | 06:54 PM
Someone has to have or know of the source for the correct actuator........
Old 08-12-2005 | 08:32 PM
GOODT's Avatar
Pantera,
I'd be more then happy to get what you need but any mercruiser dealer can get it, sorry i didnt know you had a single here is the info you need it comes from mercruiser EPC ( ELETRONIC PARTS CATOLOG ), They only make one actuator for it !!!~heres the info for that
Attached Thumbnails Drive Trim Actuator For Merc. Indicator-ind-003.jpg   Drive Trim Actuator For Merc. Indicator-act.jpg
GOODT is offline
duksrule
3
07-06-2006 06:51 PM
Elite Marine
Pantera
10
04-15-2006 07:53 PM
Elite Marine
0
07-08-2005 09:46 PM
Elite Marine
Pantera
0
06-29-2004 06:07 PM
puder
9
05-16-2003 06:01 AM
