Mercruiser 420 HP specs. >
Old 08-11-2005 | 09:27 PM
Default Mercruiser 420 HP specs.
I just bought a 1978 23ft Seacraft Seavette. It has the Mercruiser 420HP 454. I need to do a tune up on it and I would like to know the entire tune up specs. Such as timing, spark plug type, plug gap, idle RPM, etc. Some one has apparently replaced the carb. It looks like a Holley 850 double pumper with an electric choke. The carb # is 9022. I understand that the original carb was an 800 CFM. What was the jetting and power valve size on the 800 carb? Would anyone happen to know the gear ratio of the TRS outdrive, and how much would the engine and outdrive weigh?
Thanks! Steve Burnsed
lost2a6 is offline
Old 08-12-2005 | 06:23 AM
Default Re: Mercruiser 420 HP specs.
9022 is a 800cfm ., the drive is a 1:5: 1 hence 1:1 trans should be a b/w 72c ,tranny weighs 110 , drive is 150 engine is just a LS6 with a crane cam , gold rockers etc.if it has a holley someone changed the intake , if not mistaken the 420 came with a alum dual plane intake and quadrajet carb.
same question you have-
http://www.offshoreonly.com/forums/s...420+mercruiser
some came with the 800 a also
use the "seach" option on the right top of screen . find anything you want....
open87 is offline
Old 08-12-2005 | 07:23 AM
PatriYacht's Avatar
My 420's came with Holley 800s and Wiend Xcellerator intakes. The old Merc Cyclone 400 was the same engine except it had a Quadrajet and a Chevy high rise intake.
PatriYacht is offline
Old 08-12-2005 | 07:55 PM
Thanks guys. It does have the Weiand single plane intake. I'm thinking about trying a GM duel plane high-rise intake just to get a little more bottom end out of it. What kind of RPM should this engine be turning? With it not running right I was only getting 4600 RPM. Right now there is no GPS on the boat so I don't know how fast that it is running, however it has a 23-pitch wheel
lost2a6 is offline
Old 08-14-2005 | 01:36 PM
Big Block Billy's Avatar
Merc 420 motors came with no longer availiable huge iron manifolds with cast in individual runners. Also had a bigger elbow. Basicaly , twice the opening size of a stock manifold (330 ) I can't see the motor making more than 385 Hp with stock manifolds, Unless they are the High perf ones. Maybe you will be using headers. I have some of the big manifolds,
and related parts pipes etc. , Hard to find. Check out Mercruiserparts.com , and look up exhaust system under 420 . BBB
Big Block Billy is offline
Old 08-14-2005 | 10:55 PM
I have the merc 420's.
I have the GM high rise alum intakes and holley 800 dbl pumpers. My jets are 71 primary, 84 secondary with power valves in the primarys only. I also have the original 3" log manifolds which I feel are robbing me of HP. Im going with 4" manifolds next season
MILD THUNDER is offline
Old 08-15-2005 | 07:28 PM
Wink Re: Mercruiser 420 HP specs.
Oh Forgot to mention the intake manifold's should end in a 218 # And bear the Winters foundry snowflake !
They should have a bronze crossover as well as bronze inserts in the rear. BBB
Old 08-16-2005 | 10:31 AM
Crazyhorse's Avatar
The manual suggests turning the 420 to 5200 rpm.
Crazyhorse is offline
Old 08-16-2005 | 03:05 PM
Payton's Avatar
Charter Member #927
I've got 2 of these if anyone need them.
Payton is offline
Old 08-17-2005 | 02:23 PM
batty's Avatar
i ALSO HAVE 2 OF THESE ARE THESE GOOD INTAKES? THEY WERE REPLACED WITH THE WIEND XCELERATOR SINGLE PLANE INTAKES
batty is offline
