WOW .. Increase HP and Performance w/... >
Old 08-17-2005 | 04:31 PM
mobilecal's Avatar
Registered User
Default WOW .. Increase HP and Performance w/...
Saw this website and it is quite the additive. Very very pricey though. Its a catylst that decreases metal fatique, increases hp 10-35%, cleans emissions, decreases sox nox and hydrocarbons. Also lowers sulfur. Has anyone heard or seen this before? If so how did you like it??
Check it out..
http://www.myextremeresearch.com/enviromax.asp
mobilecal is offline
mobilecal's Avatar
Registered User
Default Re: WOW .. Increase HP and Performance w/...
Fuel Borne Catalyst (FBC) combined with fuel soluble carrying agents used at the ratio of 1:640, or one (1) gallon to every 640 gallons of fuel. Can be used in Gasoline, Diesel, RFG, Biodiesel, and Propane.
Use in Cars, Trucks, Diesels, Motorcycles, RV's, Tractors, Lawnmowers and Garden Tools, Snowblowers, Generators and more!
Properties: * Increases fuel economy 10 - 35 % on average, which creates a value-added product by offsetting the purchase price and returning a net savings to the end user.
* Reduces wear metal contaminates in engine oil over 50% thus reducing costly maintenance and extending the life of your engine.
* Increase horsepower and performance and boost in diesels.
* Lowers engine temperature and allows fuel to burn more efficiently and completely.
* Reduces Hydrocarbons (HC) and carbon monoxide (CO) emissions up to 80% & nitrogen oxide (NOx) emissions over 30% in most fuels.
* Reduces sulfur emissions (SOF and SOx) over 30%, and sulfur contamination of catalytic converters, oxygen sensors and in-line particle traps, while helping restore catalytic converter efficiency to near normal operational standards.
* Reduces particle matter (PM) over 50% .
Will not void warranties or harm any hydrocarbon engine.
Old 08-17-2005 | 04:32 PM
mobilecal's Avatar
Registered User
MATERIAL SAFETY DATA SHEET U.S. DEPARTMENT OF LABOR
Complies with USDL Safety & Health Regulations (20 CFR 1910.1200)
SECTION I: MANUFACTURER PRODUCT IDENTIFICATION
Maxma LC Enviro Max Plus Fuel Catalyst
PO Box 64296 Generic ID Petroleum Distillates
Lubbock, Texas 79464 MGR: 3/1/02
Emergencies: (806) 698-1305
__________________________________________________ ____________________________________
SECTION II: HAZARDOUS INGREDIENTS
% By Weight TLV (IN, PPM) CAS #
Petroleum Distillate 95.00 to 99.00% 1000 ppm – skin 95-100-8032-4
Kelly Green Dye 0.001 to 0.01% NA 91-20-3
Patented Catalyst 0.50 to 2.0% NA–non hazardous proprietary
SECTION III: PHYSICAL DATA
Boiling Point for EMP 185.2 °F to 208.77 °F
Vapor Pressure for EMP 68.0 °F to 70.0 °F
Specific Vapor Density for EMP HEAVIER THAN AIR
Specific Gravity for EMP 0.793 to 0.984
Percent Volatiles for EMP 94.00 to 98.00%
Evaporation Rate for EMP 6.80 (ethyl ether = 1)
SECTION IV: FIRE & EXPLOSION DATA
Flash Point 140° F
Extinguishing Media Alcohol foam, carbon dioxide or dry chemical
Hazardous Decomposition Products Carbon dioxide, carbon monoxide, etc
Special Firefighting Procedures Use approved self-contained breathing apparatus with full face piece.
Special Fire & Explosion Hazards Vapors are heavier than air and may travel along the ground or may be moved by ventilation and ignited by pilot lights, sparks, heaters, smoking, electric motors, static discharge, other flames or other ignition sources at locations distant from material handling point. Never use welding or cutting torch on or near drum (even empty) because product and residue can ignite explosively. Metal containers over 5 gallons should be grounded and/or bonded when material is transferred.
NFPA CODES: Health – 0 Flammability – 3 Reactivity – 0
Flammable Liquids, n.o.s. UN 1268, HC 3, PG II
SECTION V: HEALTH HAZARD DATA
Permissible Exposure Level NOT ESTABLISHED FOR PRODUCT. SEE SECTION II
Effects of Acute Overexposure
Eyes: Can cause moderate irritation, redness or tearing.
Skin: Can cause slight irritation.
Breathing: Excessive inhalation of vapors can cause nasal and respiratory irritation.
Swallowing: Can cause gastrointestinal irritation, nausea, vomiting, and diarrhea.
First Aid
If On Skin: Thoroughly wash exposed area with soap and water. Remove contaminated clothing. Launder contaminated clothing before re-use.
If In Eyes: Flush with large amounts of water, lifting upper and lower lids occasionally. Seek medical attention.
If Inhaled: If affected, remove individual to fresh air. If breathing is difficult, administer oxygen. If breathing has stopped, give CPR. Keep person warm and seek medical attention.
Route(s) of Entry Inhalation, skin contact.
SECTION VI: REACTIVITY DATA
Hazardous Polymerization: CANNOT OCCUR
Stability: Stable
Incompatibility: Has not been established for this Product.
SECTION VII: SPILL OR LEAK PROCEDURES
Steps To Be Taken In Case Materials Are Released Or Spilled
Small Spills: Eliminate all sources of ignition such as flares, flames, including pilot lights and electrical sparks. Absorb liquid or paper, vermiculite, floor absorbent material and dispose properly.
Large Spills Eliminate all sources of ignition such as flares, flames, including pilot lights and electrical sparks. Persons not wearing protective equipment should be excluded from the area of the spill until clean-up has been completed. Stop all spills at source, dike area of spill to prevent spreading; pump liquid to salvage tank. Remaining liquid may be taken up on sand, clay, earth, floor absorbent, or other containers. Prevent run-off to sewers, streams, or other bodies of water. If run-off occurs, notify proper authorities.
Waste Disposal Method
Small Spills: Allow volatile portion to evaporate in hood. Allow sufficient time for vapors to completely clear duct work. Dispose of remaining material in accordance with applicable regulations.
Large Spills: Destroy all liquid by incineration. Contaminated absorbent may be deposited in a landfill in accordance with local, state and federal regulations.
SECTION VIII: PROTECTIVE EQUIPMENT TO BE USED
Respiratory Protection: If work place exposure limits of this Product is exceeded (See Section II), use of a NIOSH/MSHA approved air supplied respirator is advised in absence of proper environmental control. OSHA regulations also permit other NIOSH/MSHA respirators (negative pressure type) under specified conditions. Engineering or administrative controls should be implemented to reduce exposure.
Ventilation: Provide sufficient mechanical (general and/or local exhaust) ventilation to maintain exposure below TLV(s).
Protective Gloves: Wear resistant gloves, such as neoprene.
Eye Protection: Chemical splash goggles in compliance with OSHA regulations are advised. However, OSHA regulations also permit other type safety glasses.
Other: Wear impervious clothing and boots to prevent repeated or prolonged skin contact.
SECTION IX: ENVIRONMENTAL DATA
Community Planning and Community Right to Know Information: this Product contains no chemicals subject to SARA Title III,
Section 3123 Reporting. THE INFORMATION ACCUMULATED HEREIN IS BELIEVED TO BE ACCURATE, BUT IT IS NOT
WARRANTED TO BE ORIGINATING WITH THE COMPANY. RECIPIENTS ARE ADVISED TO CONFIRM THAT
INFORMATION IS UP TO DATE, APPLICABLE, AND SUITABLE TO THEIR CIRCUMSTANCES.
Old 08-17-2005 | 04:39 PM
mopower's Avatar
Toxic FORMULA
Another snake oil
How many additives have ther been over the years that promised the world? Usually associated with gas shortages or price hikes
mopower is offline
Old 08-17-2005 | 04:40 PM
mobilecal's Avatar
Registered User
Up to 35% increase in gas mileage (miles per gallon).
Save on future engine repairs and/ or tune-ups by reducing engine wear and tear up to 80%.
Increases Horsepower & Performance in all gas engines.
Up to 20% boost in power for Diesel Engines.
Displaces water in your engine.
50 - 80 % reduction in Emission of Pollutants through Exhaust - do your part to save the Environment!
Extends the life of your car.
Enviro-Max Plus will not harm your engine.
Old 08-17-2005 | 04:41 PM
mobilecal's Avatar
Registered User
look at the price.........
Special Customer Pricing:
(2) 16 oz. Bottles - $37.95
1 Case - (8) 16 oz. Bottles - $134.95
4 Cases - (32) 16 oz. Bottles - $439.95
5 Gallon Jug - 640 oz - $588.00
12 Cases - (96) 16 oz. Bottles - $1289.95
48 Cases - (384 Bottles) - $4999.95
55 Gallon Drum - $5688.00
Old 08-17-2005 | 10:08 PM
mr_velocity's Avatar
Gotta get Hydro in here to start digging.
mr_velocity is offline
Old 08-17-2005 | 10:33 PM
OldSchool's Avatar
I was just thinking that maybe Hydro had changed his screenname!!!
OldSchool is offline
Old 08-18-2005 | 07:51 AM
dockrocker's Avatar
I love it - works great with my 150 mpg carburetor! I was lucky to snag the carb from a guy selling them out of the back of Popular Science magazine - he said he had to use a P.O. Box and change the address all the time because the oil and auto companies kept trying to shut him down.
Now I get almost 200 mpg and my truck has 300 more horsepower.
dockrocker is offline
Old 08-18-2005 | 08:30 AM
Let’s see: If fuel is only combustible when mixed with air at a ratio of between 12-14:1 ....... I still don't understand how a carb can do that, or more interesting is that people actually believe it. I still hear this story from time to time.
Olds Eddie is offline
