engine over heating problem >
Old 08-22-2005 | 07:12 PM
ratman's Avatar
Default Re: engine over heating problem
all the coolers are new with the exception of the p/s cooler, which happens to be on that motor thats getting hot. i will try swapping raw water pumps from one engine to the other and will back flush everything when i swap the pumps. any other ideas? thx ratman
ratman is offline
Old 08-22-2005 | 07:21 PM
So what are the temps? If you have good flow from the exhaust I don't see how you could have a big problem unless you're really lean or way too much timing or something. Pressure means you pump is supplying but means nothing to flow,,but the exhaust flow tells you it's getting thru. I know from your nice hardware you probably know more than me , just trying to think this over with ya.
cooltoys61 is offline
Old 08-22-2005 | 07:24 PM
blue thunder's Avatar
Do you run tstats and circulating pumps? If so, either of those could be suspect.
BT
blue thunder is offline
Old 08-22-2005 | 08:20 PM
thunderusone's Avatar
If the timing has moved, IE dist issues or slipped, it will cause the temo to run up like you are talking about. It will also melt the engine quick. Get a timing light with an advance dial and check your total advance.
thunderusone is offline
Old 08-22-2005 | 08:48 PM
Ratman,
These are the engines that the guy did the not so great dyno job on?
You said the guy didn't really do any tuning on the dyno. I'm thinking along the lines of thunderusone. Timing? Carb Jetting? Are they set up like the other engine that's not getting hot? Lean carb/too much timing can make it get hot when you lean on it. Check the ps cooler, but check your plugs too.
See how they look, and compare them to the other engine.
You don't want to cook a new mill.
Liberator21 is offline
Old 08-22-2005 | 10:27 PM
ratman's Avatar
no thermastats, no circulating pumps, im running crossovers,
ratman is offline
Old 08-22-2005 | 10:31 PM
ratman's Avatar
heres a pic of the dyno numbers bsfc #'s were .52 which should be enough fuel. i have 7 lbs on one motor and 5.5 to 6 lbs on the other at wfo throttle.
ratman is offline
Old 08-22-2005 | 10:34 PM
hillbilly24's Avatar
I got a deal for ya Ratman, if you quit posting that sick krap in the UC section I will come fix your overheating problem. Deal ?
hillbilly24 is offline
Old 08-22-2005 | 10:40 PM
ratman's Avatar
define sick, does that include getting the other engine to idle? i'll pay ya
ratman is offline
Old 08-22-2005 | 11:24 PM
What aprt of Tampa do you live in ? I'm up in Hernando beach if your free Friday I can probably come check it out.
