Spark plug reading....... >
Old 08-23-2005 | 11:15 PM
vandeano's Avatar
Default Spark plug reading.......
I just rebuilt my 502 and cant figure out why all my plugs on one side are very rich (2,4,6,8) and the plugs on the other side are everything else but rich. #1 looks lean, #3 looks normal, #5 looks like its really black, #7 looks normal but rusty. (no evidence of water other then the rust) plus when I look thru the spark plug hole in #7 I see droplets on top of piston. could that be gas or would that be water? Im going to go run it it again with new plugs Instead of Champions I'm going to try AC Delco.
vandeano is offline
Old 08-24-2005 | 06:52 AM
Payton's Avatar
Charter Member #927
Default Re: Spark plug reading.......
What exhaust system do you have? Could it be an internal leak just into #7? I had that trouble with my Gils. It was repairable.
Other than that, it sounds like very uneven fuel distribtion. What carb and intake do you ahve?
Payton is offline
Old 08-24-2005 | 07:02 AM
vandeano's Avatar
Exhaust is Revolution Marine, stock manifold with stock weber carb. It a 1992 502 Mag. everything stock except for exhaust and a mild cam 139721 crane cam. Should of gone bigger on cam also changed over to roller. I just rebuilt the carb. What could cause uneven fuel?
vandeano is offline
Old 08-24-2005 | 09:07 AM
East Coast B's Avatar
How do you like the Revolution exhaust? Did you install prior to engine mods? If so, any performance difference? I hear some say yes, others say no, looking for first hand experiences....
Thanks and good luck!
East Coast B is offline
Old 08-24-2005 | 11:07 AM
vandeano's Avatar
Unfortunately I installed at the time of rebuild, so I cant really tell you. Sounds better. Could even be louder to tell you the truth.
vandeano is offline
Old 08-24-2005 | 12:25 PM
ratman's Avatar
heres a great lin for reading plugs, caveman gave it to me. spak plug reading 101 good luck
ratman is offline
Old 08-24-2005 | 06:57 PM
Hydrocruiser's Avatar
Arrow Re: Spark plug reading.......
As you know mixture robbing takes places amongst cylinders. Some intake manifolds or ecm calibrations compensate for this well.
That is why you are seeing mixed results from cylinder to cylinder.
Hydrocruiser is offline
Old 08-24-2005 | 07:14 PM
I would suspect that your problem is a leaking intake manifold. If the gasket is not quite right on the side thats running lean it could suck air. Also the water in cylinder could be from coolant/raw water from crossover in manifold.
Olds Eddie is offline
Old 08-24-2005 | 08:06 PM
Make sure that if you are running it on the trailer that you have the tongue high. Could be just flowing back.
BadDog is offline
Old 08-25-2005 | 08:50 AM
magnum27's Avatar
and get those Champion plugs out of there, from my experience those are the worst plugs made. Go with either Ac/delco or Auto lites, Auto lite makes a great racing plug that uses a stainless end that I like for one it doesn't rust up in a marine environment. Not saying that is your problem but could be later. Champion's are known to blow the porcelain out of the head of the plug leaving that cylinder open and sounds like a blown engine. I have even had this happen with the only set of Champions I ever bought. I know quite a few people that have had the same issue with Champions so it isn't a one time thing.
magnum27 is offline
