Vacuum Hookup On Dominator >
Old 08-24-2005 | 07:59 PM
Cmoney's Avatar
Default Vacuum Hookup On Dominator
I am having a little trouble getting my idle mixture dialed in on my 1050 Holley marine dominator's.
Where do you hook up the vacuum gauge, I have been trying without one, and with little success.
Cmoney is offline
Old 08-24-2005 | 08:09 PM
Vinny P's Avatar
I hate the winter!!
Default Re: Vacuum Hookup On Dominator
I drilled and tapped a hole in the manifold just under the spacer plate.
Vinny P is offline
Old 08-25-2005 | 06:53 AM
Airpacker's Avatar
If you have a space plate, drill and tap a port in it. If not, do as stated above.
Airpacker is offline
Old 08-25-2005 | 08:44 PM
Cmoney's Avatar
I have a 1inch spacer, but it is composite, do you think it will still tap ok?
Cmoney is offline
Old 08-25-2005 | 09:03 PM
Vinny P's Avatar
I hate the winter!!
I have a Wilson spacer, but was afraid to drill it. The manifold was easier for me.
Vinny P is offline
Old 08-26-2005 | 07:29 AM
Airpacker's Avatar
You can drill and tap composite no problem. You might want to use a pipe sealer on the fitting.
Ryan8886
12-02-2007 11:35 AM
oreokid220
11-16-2007 03:17 PM
MES
10-02-2007 10:00 PM
Anarchy Powerboats
06-15-2006 06:23 PM
sheikman
2
05-27-2002 06:17 PM
