Oil System Plumbing >
Oil System Plumbing
Oil System Plumbing
Old 08-29-2005 | 03:54 PM
RLW
Default Oil System Plumbing
There has been much discussion in regards to what is right and what is wrong in regards to the plumbing of an oil circuit for our performance engines.
The use of 90 degree fittings is considered inappropriate for these systems. The question is, " Can one use a 90 degree swept fitting as in an Aeroquip style hose end"?
I am considering the Aeroquip 90 degree fitting as shown.
The use of 90 degree "drilled" fittings is a no-no but yet Mercury has used them on their HP motor oil circuits. ?????
One more thing to consider is that there are some thermostatically controlled oil coolers available that have an abrupt 90 degree fitting in there design. I would think that this would cause some disturbance in the oil flow as the oil bypasses the cooler and reroutes itself back to the engine.
As always thanks for any replies.
Russ
RLW is offline
Old 08-29-2005 | 04:59 PM
articfriends's Avatar
Default Re: Oil System Plumbing
Russ,if your using -12 hose its not as critical as when lines are marginal,just don't use any more than you have to. Make sure you buy whats called a "full flow fitting",Smitty
articfriends is offline
Old 08-29-2005 | 06:09 PM
RLW
Smitty,
I have been in conversation with Stef's Performance and they have done much research in oil line sizing. Their response was that they have tried many combinations of line sizes such as -10 supply and return, -12 supply and return, -10 supply and -12 return, etc.
They felt that -10 was more than adequate except for the highest HP applications (you). I checked out a Mercury Supercat motor at St. Clair and noticed the use of -12 AN exclusively. I am now leaning in the direction of using -10 AN Socketless Aeroquip hose and fittings. As you know my temps and pressures look good now but am looking for a little more volume than the Mercury HP500 setup I am using. I am looking for a little more assurance.
In your case, the -12 lines are warranted. I want to try an upgrade in line size and routing and see the results. My present oil cooler is 2" x 17" with an additional remote PS cooler. I did some searches on OSO and there are some guys using a much larger cooler than what I am running. I don't stay into it for as long as some therefore my temps are not as much as an issue. I see 220-225 at cruise and 250 after WOT. These are return temps after the cooler.
Thanks for your feedback.
RLW is offline
Old 08-29-2005 | 07:07 PM
Hydrocruiser's Avatar
Arrow Re: Oil System Plumbing
Originally Posted by RLW
Smitty,
With some increased cooling you should be able to get the WOT temps down to 230's.
Hydrocruiser is offline
Old 08-29-2005 | 07:11 PM
http://www.hardin-marine.com/product...il-coolers.htm
Dual Tandem Oil Cooler 2" Diameter / 18" Length
This is one of the best designs anywhere. Two coolers and only one water hose connection. Each tube consists of thirty-one 1/4" seamless tubes with displacement baffles so you can be assured you're getting maximum cooling when you need it.
or
"The Ultimate" Hi-Performance Thermostatically Controlled CoolerQuite simply, the ultimate oil cooler on the market today! It maintains oil temperature thermostatically and all in one unit. If you suffer from either high oil temperature or even moisture or condensation in your engine oil this is the answer. The oil thermostat is designed to maintain an oil operating temperature between 190 degrees and 215 degrees. The thermostat bypasses the cooler until operating temperature has been reached and then balances oil flow to maintain optimum oil temperature. This alone can save you from years of damage caused by operating your boat with too cold oil.
Call them Hydro's choices.
Old 08-29-2005 | 07:30 PM
Hydro, thats exactly what I'm running,it is a little small for my power level but I don't go on poker runs at wot for 45 minutes,works great,Smitty
Old 08-29-2005 | 07:49 PM
[QUOTE=RLW]There has been much discussion in regards to what is right and what is wrong in regards to the plumbing of an oil circuit for our performance engines.
What specifically are you referring to when you say "drilled" fittings? Are they the 90 degree NPT to AN adapter fittings that many including Aeroquip has to offer?
ROTAX454 is offline
Old 08-29-2005 | 07:51 PM
[QUOTE=Hydrocruiser]http://www.hardin-marine.com/product...il-coolers.htm
or
Is what you are saying is the Thermo unit opens at 215 and closes at 190? Just trying to get a handle on the numbers.
ROTAX454 is offline
Old 08-29-2005 | 08:35 PM
RLW
Rotax,
When I refer to a drilled fitting I mean something along the order of Item #21 in the below picture.
RLW is offline
Old 08-29-2005 | 09:04 PM
Maybe the thermostat controlled cooler is not the right one for you..try the dual set-up. I knew a guy with blown 502 that ran a twin dual set-up...prior was seeing 290*F at WOT for 15 minutes and after was right around 230*F max.
No excuse for oil that is too hot...you just keep plumbing in more surface area...a twin dually always does the trick I am told.
He has a radiator shop plumb the 2 units in a parrallel configuration and essentially have one inlet and outlet. It's all about surface area..temps went down..oil pressure was normal...engine life doubled compared to previous...added extra oil volume as well to the system.
Heat is your engines worst enemy....and oil heat is what they are talking about too...never forget it!
