trim out while driving? >
Old 08-31-2005 | 07:26 AM
gsmith9898's Avatar
Default trim out while driving?
I have a eliminator daytona. I see other cats that throw a huge rooster tail when ripping across the lake. When I trim out till it fills good than I don't throw much of a rooster tail but when I over trim it the tail gets up there. Can you over trim and hurt the drive or lose water to the pump?
gsmith9898 is offline
Old 08-31-2005 | 07:46 AM
monstaaa's Avatar
Default Re: trim out while driving?
deifeatelt can hurt the drive, and depending on where you pick water up from , yes yoy could loose water pressure.
monstaaa is offline
Old 08-31-2005 | 01:11 PM
Airpacker's Avatar
Your daytona doesn't throw much tail because the drive is only semi surfaced. Trimming for a tail ia a waste of power and fuel. It also over works the u joints for no reason. Want a tail, slam a black hawk on it. Click my signature link to see what happened to my daytona.
Airpacker is offline
Old 09-01-2005 | 04:07 PM
Sean H's Avatar
A to Z
the cats you are watching most likely have sixes or surface drives... your bravo boat won't produce that kind of tail.. a shorter lower/higher x can start to throw one, but not what you are talking about i don't think... round ear props like bravos work much better under water than on top of it unlike clever style props... also those boats have thru-hull water pickups so the drive doesn't matter, you can raise the bravo to high and have water pressure issues... (like none)
Sean H is offline
Old 09-02-2005 | 06:37 AM
throttleup's Avatar
The rooster tail is more common with surface type drives under acceleration. When the boat is properly set up and properly trimmed there should not be a rooster tail at top speed. Just a hump of water and mist behind the boat.
When you see a boat running at top speed and shooting a rooster tail they are either trimmed too high and shooting a rooster tail for the show, or the boat is not set up properly.
Matt
throttleup is offline
26sonic
Sonic
8
05-12-2006 09:23 PM
packinair
11-08-2004 04:11 PM
SHARKEY-IMAGES
08-03-2004 04:09 PM
