Any Merc coupler upgrades? >
Old 09-05-2005 | 11:53 AM
born2burn's Avatar
Default Re: Any Merc coupler upgrades?
Thanks Panther. That part # comes up as steel spline hub designed for low speed/work conditions. Im assuming like for diesels. Are you sure this is the correct one I want for high HP and high TQ in my 26' cat?
born2burn is offline
Old 09-05-2005 | 04:53 PM
Panther's Avatar
Frank's Marine Service
If you look up the merc HP525 or any of the other HP motors, you should see the "A11" (stock is "A8") as an option.
Panther is offline
Old 09-05-2005 | 06:46 PM
formula31's Avatar
Originally Posted by DiamondPerformance
Make sure you have the right bolts for that coupler, the bolts have a shoulder, if not the coupler will move. The new coupler will come with the right bolts.
They used to have shoulders, but now are standard bolts when ordered from Merc, threaded full.
formula31 is offline
Old 09-05-2005 | 10:56 PM
2112's Avatar
Do they use washers now?
Are the old shouldered bolts still available?
2112 is offline
Old 09-06-2005 | 06:28 AM
DiamondPerformance's Avatar
Offshoreonly Advertiser
I just put a new coupler on a Cigarette and the bolts had a shoulder on them, they came with the coupler.
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
DiamondPerformance is offline
Old 09-06-2005 | 10:59 AM
Panther's Avatar
Same here. I put one in my boat about a month ago and it had shoulders. One thing that I didn't like is they no longer put the thread locker on the bolts so I had to put some loctite on which took a little more time.
Panther is offline
Old 09-06-2005 | 10:27 PM
Craig B's Avatar
Sorry to threadjack,
Who has the best deal on engine couplers? Maybe save me from looking around...
Craig B is offline
Old 09-06-2005 | 10:53 PM
Originally Posted by checkmate454mag
I have had good success with Mercs steel hub coupler. The splines are steel and extend out past the rubber coupler a few inches.
I'm running this coupler also on a hopped up 525sc. I was thinking the same thing about the bolts. The coupler comes with new ones.
Griff is offline
Old 09-07-2005 | 07:38 AM
Donman's Avatar
I`m needing a coupler too and was also curious as to what is the best deal out there.
I found a stock, aluminum spline Merc coupler for $344.94 at www.mercruiserparts.com
List is $404, exactly what my local Merc dealer wants....
Anyone know of a better deal than $344 ???
Donman is offline
Old 09-07-2005 | 10:47 AM
Give a call to Marc Berman, he runs mercuiserparts.com. He knows about couplers, transmissions and drives.
tomcat is offline
