Twin inboard to single Conversion? >
Old 09-06-2005 | 10:25 AM
Default Twin inboard to single Conversion?
I have a 1978, 23' Formula with twin 350 chevy. It needs repowering. I am thinking of convertiong it to a single 350 for economy of the whole process. Any thoughts? Anyone done this? Thanks
Jay
az28 is offline
Old 09-06-2005 | 11:12 AM
mopower's Avatar
Toxic FORMULA
Default Re: Twin inboard to single Conversion?
A lot of work and a lot of expense to do a conversion like that.
And don't think for one minute you will double your mileage with only one engine .
You'll loose 1000 lbs but one engine will be working a lot harder
If it still runs reasonably well , sell it and get something different. It will be a whole lot easier and cheaper in the long run.
mopower is offline
Old 09-06-2005 | 12:30 PM
magnum27's Avatar
If you want to switch to a single, go to a single big block, a single small block will be a pig in that boat
magnum27 is offline
Old 09-06-2005 | 12:35 PM
I agree with Magnum27,
A single 454MPI, 502MPI or a 496 will do your classic Formula to a realy nice boat. With friends and knowledge you will do this oparation easy.
Mange is offline
Old 09-06-2005 | 06:44 PM
Does anyone know what will or will not fit from a small block
conversion besides the exhaust, and intake? Are the drive units the interchangeable, on cars the trannys will interchange
from small to big block. I thought I would make new motor mount, cut new hole for the (centered) drive location, fill the old holes in the transom and be pretty much in business. What am I missing? Thanks again! I would prefer a Big Block
in everything!
az28 is offline
Old 09-06-2005 | 06:56 PM
bowtie's Avatar
You probably have Alphas, you don't want them with a big block. Not much else other than the wiring harness, maybe starter and alt., and if you rejet the quadrajet its the same. Expensive conversion for a 27 year old boat. You'll never get your money out of it.
bowtie is offline
Old 09-06-2005 | 08:14 PM
I agree with Mopower and Bowtie.......unload it and get the boat you want...............MUCH easier.........doug
pullmytrigger is offline
Old 09-06-2005 | 09:33 PM
Dont know where you are from but converting a twin to single is sacreligious if I can spell that. Ocean boats should have twins (separate electrically / fuel / etc ) for reliability and converting a twin 2 a single will significantly reduce the value of your boat. If you are a lake guy you really dont need the extra reliability but differential thrust from a twin shure makes docking and putting on the trailer alot easier. Your boat may be old but dont ruin it. Just my thoughts....TJ
tj309 is offline
earl_dame
Chris Craft
6
10-20-2006 09:21 PM
offthefront
02-11-2004 05:44 PM
KN
08-25-2003 08:28 AM
propless
Magnum Marine
3
09-05-2002 09:31 PM
GameOver
Baja
3
07-28-2002 05:32 PM
