Do I Need A New Alternator? >
Old 09-26-2005 | 02:01 PM
WHOSNEXT's Avatar
Default Re: Do I Need A New Alternator?
replaced alternator last week....charging @ 13.8....problem solved...thanks for all your help.
WHOSNEXT is offline
Old 09-26-2005 | 09:09 PM
dykstra's Avatar
Good deal!!!
dykstra is offline
Old 09-27-2005 | 11:23 AM
I also have the same problem, charging at less than 12V. However, I've steered away from the problem being alternator-related since both engines/gauges read low, exactly, at the same time. It is not logical to think both alternators are equally faulty.
Am I not correct here? Would one bad alternator make both engines/gauges charge and read low?
I've been chasing other common points between the two engines such as dash connections, engine connections, battery switch, etc. Actually, I just replaced the battery switch because it was so hard to turn, really grinding away inside the switch. I'm hoping maybe the switch was partially shorting out. Haven't checked it though, she's laid up for the winter now.
ThirdBird is offline
Old 09-27-2005 | 11:34 AM
5PMSMWHR's Avatar
I had same symptoms this year and it was batteries. When I checked the date code they were 6 years old! They were due to be replaced. Third, your problem is you need to trade old ironsides for a clean '99 Donzi 28zx brother! The SBCs will fit into your miserly running style and you'll look alot better when ya finally do catch up!
5PMSMWHR is offline
Old 09-27-2005 | 06:22 PM
plumbers crack's Avatar
Talking Re: Do I Need A New Alternator?
I wouldnt disconnect any alternator to check voltage especially a marine alternator.Taking the lead off causes the alt to spike and you will definately cook it!
plumbers crack is offline
Old 09-30-2005 | 10:50 AM
Turn the battery switch off while the motor is running....if it shuts off it's a good indication you have a problem with your alternator.
37Talon is offline
baja27
0
09-23-2008 08:57 AM
David Stotz
11
12-16-2007 12:43 PM
itilldo
07-06-2006 07:44 AM
synack
3
05-01-2006 06:43 PM
timewarp
3
03-03-2002 09:31 AM
