-   -   Replacing ignition switch (https://www.offshoreonly.com/forums/general-q/111867-replacing-ignition-switch.html)
H2X BOSS 09-07-2005 10:24 AM
My ignition switch failed this weekend in my Baja H2X. I am thinking or making a custom setup, possibly with a push button start. Last time I used a airplane switch with cover plate. Anyone have a pics of their ignition or any ideas of where to buy a ready made push button starter?
RYAN JOHANSEN
2000 BAJA H2X BOSS
allenk4 06-12-2007 02:10 PM
What did you ever do with this project?
Pictures if you have any
rdoactive 06-12-2007 02:29 PM
I've set up a couple engine room control boxes with the wiring harness plugin, an ignition on/off toggle with a cover plate, and a push button start switch. It made tuning and winterizing easy.
Never did it at the helm. If you do, be sure to use a push button switch with a guard around it. There might be bad results for your starter or flywheel gear if you accidentally hit it at 5000 rpm.
Gary
