Staggered Engines?
What Is The Reason Some Boats Have This Setup??what Are The Performance Gains Or Losses?? Just Curious!
Re: Staggered Engines?
Gain!!! Weight distribution is moved forward and center. I believe because of placement, lower center of gravity as well. Working on the motors I imagine would be easier as well... Wish I had staggered.
All good responses!!
In addition you can bring the props closer together. Which translates to more Speed. Gerry |
Can create difficulty using certain drives if you have a notched transom. I have staggered with a notched transom, could not switch to arneson drives without filling in the notch.
| All times are GMT -5. The time now is 11:30 PM. |
