More prop/drive questions - for the experts >
Old 09-13-2005 | 11:35 AM
mr_velocity's Avatar
Default More prop/drive questions - for the experts
I've been talking to a friend of mine that has been breaking Bravo drives about props. I've been running the same 96 Bravos behind my 41 Velocity for about 10 years, 7 of those years has been behind 600 hp motors. I spend a lot of time in the ocean, but other than taking 1 tooth off a gear in 00, I haven't been breaking drives.
I was wondering if it had to do with the props, I run labbed B1 props but I did cut the diffuser ring off. Would that provide enough slip so the drive doesn't get hammered? Or is the RedLine Heavy Shockproof oil just that good?
mr_velocity is offline
Old 09-13-2005 | 11:46 AM
Default Re: More prop/drive questions - for the experts
What pitch props are you running? Do you use a drive shower? Are the motors N/A or S/C? What is yout top speed and rpm?
cobra marty is offline
Old 09-13-2005 | 12:03 PM
28P, drive showers, NA motors, 5600rpm on a good day, top speed, mid 80s on speedo.
Old 09-13-2005 | 01:51 PM
A couple of years ago I did a survey of owners with broken Bravos and what was found was that drive showers, external steering, 26-28"pitch or less props, synthetic drive lube were ALL benificial. In fact, none were broke with all the above. Your N/A engines have less TQ than S/C motors and that is good for not breaking drives. So you have all the right things to not break a drive.
IRONMAN
26
03-08-2007 08:41 AM
2 Trick Rick
6
11-17-2006 08:19 AM
KN
12
11-27-2005 02:44 PM
tomtbone1993
Baja
16
03-18-2005 07:09 AM
alj
9
10-13-2004 04:03 PM
