Pick your upgrade for Twin 5.7s >
Old 09-14-2005 | 11:57 AM
yikes's Avatar
Default Pick your upgrade for Twin 5.7s
I bought my 86 Daytona on Ebay a few years ago. It has twin 260 HP small blocks. I just installed a counter rotation Aplha 1 lower and switched to 23p Mirage props. WOP is 4500rpms at 61mph on gps. I am looking for advise about my next performance mod. The boat is all stock power with prop exhaust. My budget call for one a year because it's a twin and you always have to buy two of everything.
Pick whats next!
1. Thru hull exhaust w/manifolds.
2. External steering.
3. Drive showers.
4. KNN air filters.
5. MSD ignition modules.
6. Carb & intake.
7. 383 small blocks.
8. You tell me.
Please help.
yikes is offline
Old 09-14-2005 | 02:53 PM
Default Re: Pick your upgrade for Twin 5.7s
#3 "now" $130.00 X 2
#1 Let It Breath
#6 Nickerson For Carbs
#5 Your Going To Get Beat Up On This One I Have It On My Sbc And I Can Tune Timing And Rev Limiter
#2 Only If Your Going +70 ???
Badtoon is offline
Old 09-14-2005 | 03:08 PM
yikes's Avatar
Thanks I guess showers are cheap insurance. I was concentrating on the steering but I think I would enjoy the pipes.
yikes is offline
Old 09-14-2005 | 03:11 PM
Save your money for gas and enjoy what you have. Its takes alot of HP to gain MPH.
1BIGJIM is offline
Old 09-14-2005 | 03:13 PM
The only thing on that list that will make it go faster is #7.
A cam swap might help top end if your existing heads will flow the extra volume. If not, make it a cam and mild head work. Then change the exhaust.
BTW, your drives probably wont hold up to blower or big block power.
Gary
Gary Anderson is offline
Old 09-15-2005 | 06:54 AM
yikes's Avatar
I want to get to 70mph. I think it can be done with the motors at 5200 at WOT. I would think that the stock 260HP motors could be hopped up enough to get it done. I know the boat can handle it.
If I settle for 60 should I change the props? It comes on plane OK with the 23s.
yikes is offline
Old 09-15-2005 | 07:40 AM
Donman's Avatar
Thumbs up Re: Pick your upgrade for Twin 5.7s
If it were my boat, I`d upgrade the heads, cams, intake and carb.
While I had the manifolds off, I`d cut holes in transom and put the exhaust out the back...make it loud.
You probably won`t hit 70 with those parts, but mid-60`s should be possible.
Donman is offline
dhlaw
Cigarette
11
02-27-2006 07:15 AM
fastlane40
Eliminator
2
12-15-2005 09:38 AM
Shah Mat
11
12-29-2004 03:50 PM
Tim G.
Pantera
8
04-12-2004 07:29 PM
BACK 4 MORE
01-15-2002 10:57 AM
