My 12 hour 555 just blew up >
Old 10-21-2005 | 01:57 AM
  #31
Default Re: My 12 hour 555 just blew up
Mike- I always seem to go south, but I'm always game for a new place. We take a family vacation every summer, and try to go to a different place each year. Do you know of any resorts that have a big house (or 2) that can handle 25 people? Please let me know if you do.
Ray- I'll search the threads to see what I can find. Thanks again.
toolz is offline
Old 10-21-2005 | 08:07 AM
  #32
KAAMA's Avatar
Originally Posted by Mike&Paula
Hey You IL boys, Ever Get Up to the Chain o lake or to Lake MI? I spend a lot of time out on the Chain since it in my back yard.
Sorry not trying to Hi-jack your thread
Mike
Mike, I brought my boat up there for the first time this year for the Northern Michigan Fun Run and Elk Lake through the stump fields to Torch Lake---I will be doing A LOT more boating up there from now on!
Toolz, trailering your boat up there is worth the trip---the water clearity is awesome and the scenery is great. Lots of great boating up there!
If you really want to nail down a cam for your engine CID, and application/combination then rmbuilder or Cstraub are good cam tech guys.
KAAMA is offline
Old 10-23-2005 | 11:58 PM
  #33
Johnny DCB's Avatar
Toolz,
Sucks to hear about your motor.Heres something to read from alot of the members here about lifters.
http://www.offshoreonly.com/forums/s...d.php?t=101897
Johnny DCB is offline
Old 10-25-2005 | 12:41 AM
  #34
Johnny- Ran across that thread a while back, but it was good reading it again. Thanks. I think I've decided on the Morel hydraulics. I'm not going to end up with much over .600 lift and around 5600 rpm max, so I think it makes the most sense. Still need to decide on a cam. I've used CamMotion for the custom cams in my drag cars, and was very pleased every time. Anybody used them in a boat? Thanks again.
toolz is offline
Old 10-25-2005 | 02:39 AM
  #35
Originally Posted by Raylar
Sorry for your engine problem on a new motor, but I thought I would bring up a point that some performance boaters may be missing. Not sure if this applies in your case, but it sounds possible. On solid lifter cams it is imperitive to break in the cam and lifters. You should always use a moly or approved break in lube generously on the lifters and the cam itself. When the engine is first started, it needs to be run continously at about 2000 rpms for about 10-15 minutes. This actually sets a proper crown wear point on the cam and lifter that match and keep the cam from cutting metal off the lifter face or cam. If solid lifter cam and lifter is not done correctly it many times will destroy solid lifter faces and cam lobes and the resulting metal particles can get into lifter bores and really mess things up. Another item sometimes overlooked in engine builups is properly preparing lifter bores and checking for proper lifter to bore clearances.Not saying either of these procedures are responsible for your loss, just trying to educate boaters who spec. and have their engines built that great engine building comes from attention to detail. Anybody can do the big things, in an engine its the details that count!
Good Luck,
Ray @ Raylar
In addition to this, if you are running a big cam with a lot of spring pressure it is better to break it in with some softer springs (or if dual springs, remove the inner spring). Also, some rocker manufacturers even make break in rocker arms which have a ratio of like 1.1 to 1 to effectively reduce your lift by about 35% which will help prevent excessive wear during break in. These rockers are especially helpful if you plan on using it on several motors and do not feel like having to mess with removing and setting up spring pressures with the heads on the motor.
fastestbowtie is offline
jmherbert
2
07-16-2007 03:54 PM
800XCR
9
03-17-2007 02:02 PM
800XCR
02-19-2007 08:41 PM
800XCR
3
02-16-2007 11:00 AM
John B
2
12-22-2002 10:03 PM
