-   -   steering questions (https://www.offshoreonly.com/forums/general-q/113531-steering-questions.html)
mcrsr 10-02-2005 08:46 AM
steering questions
i currently have the stock merc power steering setup w/ single cable, it has 2 bravo drives w/ the tie bar in boat on the tiller arms, anyway, i just got the boat to run 71 mph and was wondering if this was ok w/ the stock system, do i need to add anything?? was considering putting on the external tie bar, any thoughts???
GoCiggie31 10-02-2005 09:17 AM
Re: steering questions
Hi,
Check out the below threads for starters.
http://www.offshoreonly.com/forums/s...ernal+steering
or
or go to search section and type in the topics and enjoy the reads.
I am pondering the idea and trying to sell the wife on such an expense.
Good luck
mcrsr 10-02-2005 09:55 AM
boy, i'm glad i'm in the same boat as you, my wife would have a hard time digesting the price!!!!
BajaBennett 10-02-2005 03:07 PM
Gentllemen,
I have externial system for sale. It a Marine Machine with only 16 hrs on the system. It includes rams, ram brackets, ram fastners, bracket fastners, wing plates (twin Bravo I) drive fastner extentions. Photo's available. Asking $1,950.00 plus freight.
Thanks,
Dail
GOODT 10-02-2005 03:11 PM
External is the best way to go but at the very least you should install a tie bar on the drive that will at least help save the steering pins some what!!!
monstaaa 10-02-2005 07:36 PM
with out question.
Outdrive1 10-02-2005 09:08 PM
Originally Posted by BajaBennett
Gentllemen,
Thanks,
Dail
That's a real good price. You can't touch two rams, wing plates, brackets etc for under 2k anywhere. External steering, at least the add on system is a must at 70 mph.
Find out if that price includes the Brazil valve too.
GoCiggie31 10-02-2005 10:14 PM
Gentllemen,
Thanks,
Dail
Dail,
That does sound like a decent price,so would this be considered an add on? Can this be upgraded later as a full system should I decide later. Can you please send pics to [email protected]. or post them on this thread for all to see.
Does anyone know what the flat rate(avg install time) is on installing this. For a novice that turns wrenches quite well?
Now to catch up on honeydue projects to try and convince the wife that we MUST spend more on my hobby. :evilb:
US1 Fountain 10-02-2005 10:57 PM
Add-ons can be upgraded to full hyd at a later date. Had an add-on on my last boat. Rock solid.
BajaBennett 10-03-2005 07:13 AM
GoCiggie31,
US1Fountain is correct above. You can add the internal at any time. I will Email you the photo in just a few min.
Thanks,
Dail
