Store with gas tanks full or empty? >
Old 10-04-2005 | 01:05 AM
Default Re: Store with gas tanks full or empty?
Originally Posted by 4mulafastech
I read a while back on another thread about the problem of gas coming out of the vent during storage. It is not the gasoline (liquid) that is expanding to any significant degree, but rather the vapor in the gas tank. Say you have a half tank of fuel and the trailer is cranked up with the boat is nose high. There is a lot of trapped vapor in the front of the tank that will expand on those warm days and literally pushes the gasoline out the vents. Putting the boat nose down so the vent taps into the vapor pocket allows it to "vent" (no pun intended) and you don't push liquid out. Makes sense to me... Just need to have the boat stored indoors so no other liquid (rain water) gets trapped into the nose down boat hull...
That would depend on where the vent hose enters the tank. Mine enters at the very front of the tank so nose up to let air out would be better.
I actually fill them to about 100 gallons of the 120gallon capacity. I have to run at least 92 octane an dthats the highest octane I can get at the pump here. In the Spring, I add 10 gallons of 114 octane to bump it back up.
Griff is offline
Old 10-04-2005 | 07:25 AM
Chris288's Avatar
as empty as possible, with stabil,, I would rather have 100 gallons of fresh gas in the beginning of the seaon.
Chris288 is offline
Old 10-04-2005 | 12:36 PM
RLW
Originally Posted by GOODT
Rlw the problem with that is you will get condensation ie water
Not worried about condensation as much as I am worried about delamination.
RLW is offline
Old 10-04-2005 | 01:47 PM
BURNSMAZZ's Avatar
Bob Teague had a question thrown at him like that(in Powerboat), he said with the quality of todays fuels he does not recommend leaving that much fuel in your tanks for that long of a time period.I think he said around 1/4 tank.
BURNSMAZZ is offline
Old 10-04-2005 | 02:22 PM
Reckless32's Avatar
Rough Seas Lie Ahead
If your winter is long then you have a real concern. If they're relatively mild and somewhat short I don't think it's big concern for newer boats, but may be for ones that have been thru a few winter's. Stabilize whatever you've got in it, and get it running as early in the spring as possible with Dry-Gas additives and octane booster. Change your filter/s once or twice in the spring just for added measure.
Reckless32 is offline
Old 10-05-2005 | 03:26 PM
dyno's Avatar
Charter Member #655
1/2 full, I was told by my engine byuilder that gas only has a 6 month octane life so I top it off with 93 in the spring and take it easy through the first tank.
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 10-05-2005 | 04:51 PM
and add dry gas in the spring.
Pismo10 is offline
Old 10-05-2005 | 06:59 PM
Dave M's Avatar
Veteran: Navy
I think the liquid does actually expand. I filled my tank on Sunday and ran the boat for about 1.5hr. I had to of used at least 15 gallons. Yesterday I went to fill it up before going boating again and it only took 3 gallons to fill? We had a substantial change in temp and barometer between Sun and tues.
Dave M is offline
Old 10-05-2005 | 08:55 PM
AIR TIME's Avatar
I had about 10 gals in my 100 gal tank for 2 years put in 45 gals of 93 sat, took it out ran good now back in the garage until spring cause I need some glass work over the winter
AIR TIME is offline
Old 10-05-2005 | 09:21 PM
A local dealer said the latest thinking is less worry about condensation and more concern about fuel degradation. Therefore, stabilize whatever is left in the tank in the fall and fill with fresh fuel in the spring. I always used to fill the tank with stabilizer added in the fall. No more.
Escape Velocity is offline
