When to change exhaust manifolds >
Old 10-06-2005 | 08:49 AM
gripit's Avatar
Default When to change exhaust manifolds
I have 420 HP's with 600 hours. I wanted to freshen them up and was wondering what I should have done to them to get another 600 hours out of them? Also, when do you know its time to change the exhaust manifolds? I have Gil exhaust and I see some slight corrosion but wanted to prevent the problem of getting any water leaking in the engine. What should I do? Are manifolds the weakest link to potential problems?
gripit is offline
Old 10-06-2005 | 10:03 AM
PatriYacht's Avatar
Default Re: When to change exhaust manifolds
How old are the manifolds? Salt water or fresh?
PatriYacht is offline
Old 10-06-2005 | 12:01 PM
hillbilly24's Avatar
you should defenitly pull the elbows and change the gaskets. While you have them off inpect the surfaces, if there is pitting and corrosion then the manifolds and elbows need to be changed.
hillbilly24 is offline
Old 10-06-2005 | 02:33 PM
OldSchool's Avatar
With 600 hours of salt water use, they have more than out-lived their usefull lifespan!! Spring for some new ones this winter....before it's too late.
OldSchool is offline
chaparral 2550sx
08-20-2007 01:08 PM
GOFASTJUNKIE
08-01-2007 01:09 PM
35 White Lightning
Fountain
0
04-01-2007 08:58 PM
SOFPilot
4
03-05-2006 09:48 PM
BajaBuddy
10
06-29-2003 10:25 PM
