K-Plane Modification Question >
Old 10-06-2005 | 07:13 PM
Poorsche's Avatar
Default K-Plane Modification Question
I've got the 19" K-Planes on my boat and the fork lift operator hit it such that a chunk broke off. I'm going to have it welded back together and I was wondering if it was possible to extend them at the same time by welding on an extension--maybe 6'" to 10" range?
I know there are replacement planes available but a little welding of correct material and braces would be a lot cheaper.
Has anyone tried this? Is there too much force on them for this to be practical?
Poorsche is offline
Old 10-06-2005 | 07:45 PM
hillbilly24's Avatar
Default Re: K-Plane Modification Question
shouldn't be a problem at all as long as you don't go too big, otherwise you will need larger clyinders otherwise the planes won't move at high speeds and you will wind up taking the internal seals in it. The only other problem is that cast aluminum is tough to weld compared to billet, it can be done just make sure you take it to someone that knows what they are doing.
hillbilly24 is offline
Old 10-06-2005 | 09:49 PM
I think you would be better off to bolt a full plate to the bottom of what you have. I believe a weld will crack sooner or later
mmwalters is offline
Poorsche
0
08-03-2004 05:55 PM
Hot Boat
2
06-06-2004 01:05 PM
magnum27
6
10-11-2003 08:37 AM
cig1988
2
03-26-2003 05:38 PM
BruceK
05-17-2002 12:55 PM
