ZZ502 - Best Replacement Camshaft?? >
Old 10-11-2005 | 04:34 AM
Default ZZ502 - Best Replacement Camshaft??
I was thinking about the Crane 168731... Would this be a good choice? Will the lift on this camshaft still work with the current stock lifters? And of course I'll be reworking the heads with the proper springs etc...
Thanks,
Gary
TROUBLE MAKER is offline
Old 10-11-2005 | 07:37 PM
Default Re: ZZ502 - Best Replacement Camshaft??
Now there's a debatable subject. Really do need more info on the motor. Completely stock? If so, what changes/upgrades do you plan? Remember, it's all about combination. Especially with the cam. Ok Chris Straub or RMbuilder, chine (chime) in.
ROTAX454 is offline
Old 10-11-2005 | 09:55 PM
Pat McPherson's Avatar
Thanks,
Gary
Yes, the 731 is the cam most people suggest.
No, you should not use the stock lifters. Some say you can, but they are on the edge.
Patrick
Pat McPherson is offline
Old 10-12-2005 | 04:14 AM
The motors will be bored to make 509's with flat top pistons, so the compression will be down just a bit over what I'm currently running. And, I'll probably do some head work to have the oval port heads matched up to the rectangular port intake manifolds that are currently installed. Will stick with the IMCO exhaust.
Old 10-12-2005 | 06:03 AM
AIR TIME's Avatar
Whats The Size # On The 731 L, C, D,
AIR TIME is offline
Old 10-12-2005 | 07:28 AM
Smitty's Avatar
I just installed the same cams in my motors and I used the stock lifters. They will work with no problems. They will not work with the 741 cam though.
Smitty is offline
Old 10-12-2005 | 07:48 AM
The heads on the ZZ's are not impressive flow numbers out of the box but with some work they respond real well. If you leave the heads stock these engines need about 12 degree split at advertised duration, an 8 degree split at .050" and need to be equal at .200" tappet height. Intake lift needs to be about .50" more then exhaust.
If ported a single pattern type cam will get you real close.
GM rates the chambers at 110cc. The last 2 sets that I dealt with were 114cc and 116 cc. Chamber size needs to be checked.
cstraub is offline
Old 10-12-2005 | 09:26 AM
Donman's Avatar
I have a "barely used" 731 roller that I will sell. It was in my Gen VI 454. It was ran 50 hours, in excellent condition. I used it with the stock lifters / COMP springs. I upgraded to a bigger cam recently.
PM or email me if interested. I`ll sell it for whatever fair market value is for a nice used 731. I paid $350 for it 18 months ago from Summit Racing.
Donman is offline
Old 10-12-2005 | 10:54 AM
AIRTIME Here are the specs for the 168731 Crane cam. I beleive it is offered in configurations to fit both the Mark IV & Mark V VI series engines. Intake lift .587, advertised duration 288, duration @ .050 226, opens 6 BTDC, closes 40 ABDC, max lift @ 107. Exhaust lift .610, advertised duration 296, duration @ .050 234, opens 54 BBDC, closes 0 ATDC , max lift at 117. These figures are based upon using a 1.7 to 1 rocker arm ratio which is standard.
Bubbletop409 is offline
Old 10-12-2005 | 02:02 PM
Thumbs up Re: ZZ502 - Best Replacement Camshaft??
Thanks for the info guys...keep it coming...
