oil temps.
Old 10-14-2005 | 03:10 PM
PatriYacht's Avatar
Default Re: oil temps.
I have Dominators 92 jets and it's not lean. 3 x 18 should be enough cooler. Check this old thread about bypass's.http://www.offshoreonly.com/forums/s...ing+oil+bypass It's good even has pictures.
PatriYacht is offline
Old 10-14-2005 | 07:24 PM
how do I determine if I have a 30 psi or a 11 psi bypass valve. How can I plug it , If thats what I decide to do .
We checked the valve today it felt like it was sticking .
boatman747 is offline
Old 10-14-2005 | 07:55 PM
RLW
My engine builder and I had this exact conversation just last week as I was curious what I had in my engine (i.e. bypass).
He told me he never uses a bypass as he likes all of the oil to go to the filter.
He also said we should be cutting the oil filters open, during oil changes, and inspecting the media for fragments.
In fact, one of our members was having oil pressure issues after a hard run. Pressure was very low at idle. He cut the filter open as recommended and discovered undesireable fragmentation. Motor came out and was disassembled to find a main bearing that was obviously the source of contamination in the oil filter. This filter inspection saved the motor components from a catostrophic failure.
Also, Oil Filter inspection is mandatory on all aircraft maintenance for this very reason.
Sorry to get off topic.
RLW is offline
Old 10-15-2005 | 08:35 AM
PatriYacht's Avatar
Makes no difference if it's a auto block or a marine block, they're all the same. All gen 5 and 6 have this oiling set up. Maybe all Merc engines come with the proper bypass, but if you are rebuilding, you throw the bypass away before hot tanking the block. The part number is in that other post I linked to. I agree it's better to plug it.
Old 10-15-2005 | 10:02 AM
How do I plug it ?
Old 10-15-2005 | 10:23 AM
PatriYacht's Avatar
My engine guy did it. I'll ask him on Monday.
Old 10-15-2005 | 03:21 PM
Mr Gadgets's Avatar
Charter Member #601
I pressed a soft plug into the opening.. worked fine for several years..
Mr Gadgets is offline
Mr Gadgets
58
12-21-2007 11:54 AM
BobbyB
15
08-08-2006 09:46 AM
BAD-HABIT
9
10-28-2005 07:58 PM
otis311
7
08-23-2004 09:58 PM
Cord
15
10-17-2002 08:32 AM
