What size oil cooler do I need ? >
Old 10-21-2005 | 01:46 PM
  #31
Default Re: What size oil cooler do I need ?
Originally Posted by Stingray69
Wobble (I think) and Teague stated that filtering after cooling was more for keeping any potential solder balls out of the oil pan.
Hmmmmm.....
Merc don't do it that way.
Also, I have yet to understand how the return oil bypass valve causes any restriction, as it is a door that opens to return oil flow at 30psi, and you have that at idle. It does not cause oil to go thru another route, to pan, but seems to be an anti drainback device, due to high mounted remote filters.
Blue Thunder explained my thoughts on oil temp sender location better than I did.
I believe the center valve is needed only when an automotive type cooler is plumbed in to the block, in the two threaded holes which are located just in front of the filter pad on the block. In a marine application when a remote oil pad and oil cooler are used, the center valve creates a restriction. cfm has posted a quote from GM on the subject. Check with him and see if he will post it again, or try a search. The GM quote gives a pretty good explanation.
Kidnova is offline
Old 10-21-2005 | 04:29 PM
  #32
blue thunder's Avatar
The bypass is actually a pressure differential valve. The poppet of the valve has pressure on both sides of it. One side is pressure from the oil pump, the other is pressure coming back after the oil went through the cooler and filter. If the pressure returning from the filter and coolers drops due to blockage, the pressure on the underside of the poppet drops and the poppet opens. This allows flow past the cooler and filter but back into the normal lub circuit towards the mains.
That is if we are talking about the same bypass valve...
BT
blue thunder is offline
Old 10-21-2005 | 08:28 PM
  #33
formula31's Avatar
Im glad Ive got mark 4's. Reading that gave me a headache.
formula31 is offline
Old 10-21-2005 | 08:56 PM
  #34
I gotta believe that in Teagueland the sun rises in the West. Where I live, (and until someone can give me a GOOD reason why I should not) I will be cooling my oil AFTER I filter it and measuring the temp. at the filter pad where it comes from the pan, compressed, and is probably at max temps. (other than directly at the load surfaces). --- Jer
jpclear is offline
Old 10-21-2005 | 09:27 PM
  #35
formula31's Avatar
Ditto,
now, is 260 before the cooler at wot acceptable or not.
Old 10-21-2005 | 09:59 PM
  #36
Now you are asking a real non-expert. I'll start by saying that I would listen to whatever cstraub says. Then I would say that I guess I wouldn't worry if I occasionally peaked at as much as 270* right out of the pan as long as that is the "occasional peak" and not the normal run temp., and I was running a good full synthetic oil. See, I avoided giving you a direct answer just like everybody else here. --- Jer
jpclear is offline
Old 10-21-2005 | 10:50 PM
  #37
I may not have seen a roller lifter develop a flat spot but I did see a roller rocker develop this with the use of 15w-50 MobilOne.
It came out of a HP525SC.
My engine builder also races in some Cat class...he uses a straight weight Kendal GT1 also....but recomends 20w-50 for pleasure use.
Applications
GT-1™ High Performance Motor Oil is recommended for use in
passenger cars, vans, light trucks and sports utility vehicles
under all driving conditions, as well as in competition engines
and high-performance street engines. The SAE 20W-50 and 50
viscosity grades are fortified to provide extra wear protection
and foam resistance for use in racing applications. The SAE 70
viscosity grade is specially formulated for use in nitromethanefueled
drag racing vehicles. The SAE 30 and 40 viscosity
grades are suitable for use in older vehicles where use of a single
grade motor oil is recommended.
Back4More is offline
Old 10-22-2005 | 09:22 AM
  #38
formula31's Avatar
Well, as funky as it sounds, im gonna add my old 7.4 coolers to the vertical water hose coming up the front of the block, theres room and it doesnt create other mounting issues like a bigger cooler will. Then toss the aluminum pans and go back to the 8 quart sheet metal ones. Least amount of hit money wise and should give me the 20 degrees I need.
J. Hordubay
13
10-02-2008 01:55 PM
team Tickfaw
9
05-21-2006 09:24 AM
RickR
10
11-30-2004 08:38 PM
Active Mike
14
03-14-2004 11:30 PM
