Oil for 2.5 efi's >
Oil for 2.5 efi's
Oil for 2.5 efi's
Old 10-22-2005 | 09:41 AM
TomFTM's Avatar
Default Oil for 2.5 efi's
What 2 stroke oil are you guys using in your 2.5 efi race motors? Also what mixture are you running? Thanks, Tom
TomFTM is offline
Old 10-23-2005 | 07:40 PM
TomFTM's Avatar
Default Re: Oil for 2.5 efi's
ttt.
TomFTM is offline
Old 10-23-2005 | 09:13 PM
I have used Mercury racing oil, mixed at 40 to 1 in all my 2.5 EFI'S and have never had a problem.
SoCalRacing is offline
Old 10-23-2005 | 09:17 PM
packinair's Avatar
No Comment
From: This post copyright, Packinair Inc. All rights reserved.
amsoil synth @ 50/1 for me... they seem to like that
packinair is offline
Old 10-24-2005 | 09:22 PM
Brad Zastrow's Avatar
I run Merc racing oil 40 to 1. I however have blown at least 5 powerheads over the years. I have owned about ten 2.5's in the last few years. They are a lot of fun and not real reliable. They are high rpm race engines.
Brad Zastrow is offline
Old 10-25-2005 | 08:03 PM
TomFTM's Avatar
Brad , what are you finding that is blowing them up? The motors I have are 2.5 280 race offshore efi's.We are in the process of rebuilding one powerhead that had 2 bad pistons. I bought the boat with one bad motor. 2000 30 ft Motion , Tom
TomFTM is offline
Old 10-25-2005 | 08:24 PM
marinetrans's Avatar
Head gasket failures is one. Needle bearing failures is another.After a while the needles "skid" or "chatter" instead of rolling .Usually on crank end.Not too many wrist pin bearing failures.Overheat or lean is one, usually piston 1 or 5.My recomendation,bearings,rings,gaskets,seals,oil pump and stator/switch boxes every year.
marinetrans is offline
Old 10-25-2005 | 10:30 PM
From 1993-2000 I ran a twin 2.5 carb (245 hp) powered Talon 22. Added 110 hp Nitrox nitrous oxide system to each engine and started using Maxima castor 927 oil. Never had an oil related failure and put 230 hours on the engines. Expensive oil, but very high quality. Burns very clean and has a really unique smell (like the little RC plane engines). My engines turned 8800 rpm on the bottle. It was scary fast...
http://www.maximausa.com/products/2stroke/castor927.asp
Attached Thumbnails Oil for 2.5 efi's-boatntrailer.jpg   Oil for 2.5 efi's-dash1.jpg
4mulafastech is offline
Old 10-26-2005 | 06:39 PM
monstaaa's Avatar
klotz is a very good 2 stroke synthetic oil, mixed @40-50 to 1. beleive it or not yamaha 2 stroke is very good as well. when you take one apart that has been using these 2 oil's the back of the piston, is very clean indicating a cleaner burn. this relates to better lubrication in vital areas as stated above due to lower combustion temps on the other side of the piston.
at least in my observations.
monstaaa is offline
Old 10-27-2005 | 06:32 PM
TomFTM's Avatar
thanks guys for the info. Tom
TomFTM is offline
tanner
09-23-2007 01:39 PM
Big Block Billy
5
05-19-2007 04:16 PM
convincor253
1
05-26-2006 10:40 PM
BamBam
03-20-2006 10:28 AM
Dusty Times
28
05-23-2004 02:01 AM
