575sci oil pressure problems? >
Old 10-24-2005 | 10:17 AM
Default 575sci oil pressure problems?
We have a 03 fountain with 575sci's. the boat sat for 2 years, we got it new in early 05. The oil pressure hovers right around 40 pounds at 4800rpm. Is this normal for these engines? I have topped it off, changed it..and nothing makes a difference. I have had the warning alarm come on once on the port engine at 3200rpm o the port engine? The guage read just below 40. Could it be plugged fittings in the block after sitting so long or??? any help would be great.
Ivan
FOUNTAINFAMILY is offline
Old 10-24-2005 | 11:28 AM
Default Re: 575sci oil pressure problems?
Mine has always been 62lbs cold and 40 when warmed up and hot. Never changes once warm. Always seemed odd to me but has been problem free for 165 hrs. Figured Merc. had it rigged that way.
zahndok is offline
Old 10-24-2005 | 11:53 AM
1st thing is to check the senders. Either replace them or chack with a mechanical guage.
Pure Energy is offline
Old 10-24-2005 | 01:04 PM
Mine are the same too.
Mine are 2002's, bought it with 150 hrs on it,
changed the oil at 160, have a little over 25
hours on the oil change, have not had to
add 1 drop of oil to either of these
What's everyones oil temp running ?
Mine will run up to 190*, then drop to
140*.
JaayTeee is offline
Old 10-24-2005 | 04:18 PM
Originally Posted by JaayTeee
What's everyones oil temp running ?.
Don't have an oil temp guage
Not to get off topic but a "save your head gaskets note" for those without a water pressure guage on a 575sci. Now that I have a water pressure guage I have observed high water pressure at 35lbs and up at wot during the winter months with colder water. I believe this is related to the thermostat closing down.
zahndok is offline
Old 10-25-2005 | 06:06 PM
Steve Zuckerman's Avatar
140*.
All the same #s on mine except the oil temp. Mine goes up to 180* (I think that's where the oil thermostat opens) and then down to 120*at cruise speed. WOT will raise it back to 140*.
By the way if your oil temp starts varying at random, you've got a clogged oil cooler. Originally thought my oil thermostat had taken a dump. Cleaned it out, no more problems.
Regards,
Steve
Steve Zuckerman is offline
Old 10-25-2005 | 06:27 PM
Thanks for the input. The oil temp is right around those #'s. Just thinking that 40 pounds was a little low, but by the way it sounds its not.
articfriends
198
04-13-2026 11:23 AM
tjsmk8
11
05-28-2007 09:40 AM
BAYVILLAS
2
07-26-2006 11:10 PM
Revd Up
6
07-06-2006 11:32 PM
zahndok
0
10-18-2004 01:11 PM
