how do you get a stuck rubber hub out of a prop? >
Old 11-07-2005 | 09:42 AM
BajaRunner's Avatar
Default how do you get a stuck rubber hub out of a prop?
I bought a new set of props for the boat, and they had a rubber style insert in them. I didnt pay attention when i put them in, as i use the solid type. Well one of them spun out at 70, i got it back to the house, pulled the props, and the one that spun, the rubber came out in pieces. The other was in tact, but twisted in there. How do you get it out? I got a piece of pipe that fit in there and beat it with a sledge and no luck. would heating and burning the rubber out with a torch work, or mess up the prop.
Im stuck.
BajaRunner is offline
Old 11-07-2005 | 01:29 PM
GOODT's Avatar
Default Re: how do you get a stuck rubber hub out of a prop?
heat it will work have done it before just make sure to do it out side
GOODT is offline
Old 11-07-2005 | 03:30 PM
cuda's Avatar
Burn, baby burn!
cuda is offline
Old 11-08-2005 | 07:17 AM
throttleup's Avatar
If you are referring to the Flo Torque 2 plastic insert it can be a little difficult to get out.
We use a press to remove them but there are some other ways that may help;
One option is to break it up with a chisel from the aft end of the prop. Be careful, they become very brittle and pieces will fly at high velocity. It will help to heat it up a little with a propane torch.
Matt
throttleup is offline
Old 11-08-2005 | 07:30 AM
Raypanic's Avatar
I would try freezing it than knocking it out.
Ray
Raypanic is offline
Old 11-08-2005 | 07:46 AM
BajaRunner's Avatar
Matt
Before I only thought there were 2 types of inserts. The plastic, and the solid. I have never seen this one before. it has a metal inside with about 1/2" of rubber all the way around it.
Old 11-08-2005 | 08:30 AM
czy40p's Avatar
May want to ask local prop shop. I would be concerned about getting the new guts back in.
czy40p is offline
Old 11-08-2005 | 08:56 AM
Mbam's Avatar
Offshoreonly Advertiser
That is the classic rubber hub, it really is not a DIY job. Murder to get out, then you need a fixture and hydraulic press to get the new one in, and it won't handle the power when you are done. Unless you have an Alpha drive (which requires a non-solid hub) it would be best to find someone who can weld a solid insert in there.
Mbam is offline
Old 11-08-2005 | 09:00 AM
BajaRunner's Avatar
I need to post a pic for you. It is the flo-torque hub system, that normally slides in and out. Ive never seen this rubber kind before. Ill post a pic tonight. I have the solid flo-torques to put back in it. Like i said, ive only ever seen the plastic and solid, never a rubber type flo-torque.
Old 11-08-2005 | 09:05 AM
Mbam's Avatar
I think you will find it is not a Flo-Torque
Mbam is offline
