OT:  Battery or alternator >
Old 11-16-2005 | 07:09 PM
Default Re: OT: Battery or alternator
If the alternator is working you should have approx. 14.5 volts DC at your battery when the vehicle is running. If 14.5 volts is present - your alternator is charging your battery. If the battery has less than that you have an alternator problem. You can check this with a volt meter set on DC with the red lead on the positive terminal and the black lead on the negative terminal.
raytart is offline
Old 11-25-2005 | 07:14 PM
MOP
If the problem is in the Durango the charger has to feed it and the battery, I would disconnect it and charge it to see if it charges better. If it does charge OK you will also get a nice little when you go to hook up the cables. At any rate it should be a dealer thing!
Phil
MOP is offline
Old 11-25-2005 | 08:07 PM
If I remember right, you should see 12.3-12.7 at battery with engine off. Running it should be around 13.5-13.7. 14.5 seems high.
MILD THUNDER is offline
BAJA WILL
02-26-2008 08:12 PM
onesickpantera
11
06-18-2007 10:13 AM
synack
0
05-09-2006 11:41 AM
tpmarine.com
New Products and Member Discounts
4
02-02-2006 09:50 AM
Formula Outlaw
49
12-09-2005 08:35 PM
