what's this mean? >
what's this mean?
what's this mean?
Old 11-21-2005 | 07:38 PM
Default what's this mean?
Blow'in some blue smoke out of the exhaust at startup and oil out of the valve cover breather.
CN24 is offline
Old 11-21-2005 | 07:47 PM
GPM
Default Re: what's this mean?
$$$$. You might start with a leak down test,
GPM is offline
Old 11-21-2005 | 08:04 PM
375stinger's Avatar
blue smoke??/is this an o/b?
375stinger is offline
Old 11-21-2005 | 08:13 PM
If youve got oil out of your valve covers and smoke from your exhaust is a sign of a worn engine with to much blow by!On the vacum stroke of a cyclinder there is oil being pulled in and burned,on the combustion stroke,the oil is being burned as well as some of the explosion entering the crank are which in now being pressurized and forcing oil out the valve cover vents!Best do a leak down test to find leak percentage of each cyclinder and youll probably hear air from the valve covers which means the rings are bad,broken,or a wall is scored,maybe a hole in the piston!good luck!
JJONES is offline
Old 11-21-2005 | 10:24 PM
Catagory5's Avatar
Thumbs up Re: what's this mean?
Bingo......
Catagory5 is offline
Old 11-22-2005 | 07:53 PM
I haven't done a leak down test yet but compression is good on all cylinders. Wouldn't the above problems cause low compression?
CN24 is offline
Old 11-22-2005 | 07:56 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Not nessesarily. Oil will create a seal between the rings and the cyl. walls giving you a false cense of a good motor because it will make for higher compression numbers. A leakdown test is best.
US1 Fountain is offline
Old 11-22-2005 | 09:24 PM
Some times Ive added oil to a low comp cylinder just to see if the comp comes up!Its a very prehistoric test but if the comp doesnt come up,its a bad valve,holed piston,if it does come up its a bad ring or two,like,US FOUNTAIN said,oil will seal the cylinders and keep the comp up!
JJONES is offline
Old 11-22-2005 | 10:34 PM
If it is only smoking at startup it could be worn valve stem seals leaking oil into the chamber.......right?
RumRunner69 is offline
Old 11-22-2005 | 10:42 PM
if valve seals leak it will let oil into the chamber and it will smoke at start up but the oil out of valve cover vents is normaly combustion pressure blowing past the ring into the crankshaft area,oil pan,which gets pressurized and pumps the oil out! valves seals are a very common seal to go bad but once the engine is running it isnt as evident,only at start up!
JJONES is offline
