Raylar BCK103 Kit Intstall Question >
Old 12-11-2005 | 03:57 PM
Harper220's Avatar
Default Re: Raylar BCK103 Kit Intstall Question
Ray, after installing the entire bp103 system, does it make the engine sound any different with the increased compression and cam change? What I'm getting at is: Does it sound any meaner??
Harper220 is offline
Old 12-11-2005 | 11:29 PM
Smile Re: Raylar BCK103 Kit Intstall Question
Harper 220:
Yes the engine has a throatier sound and a defintly sounds better under load. I would not say its louder interms of decibles but you can haear the power difference.
Rage:
I understand your inquisitiveness a little better now. If you were to install the cam and heads as a unit I would expect you would see about a 75HP increase up to about 4900rpms. The torque would probably increase by 75 - 90 ft/lbs. When you do add the intake manifold you will see the power between 4000 - 5100 rpms increase another 25 hp and the torque will increase about the same.
Ray @ Raylar
Raylar is offline
verbi69
Powerquest
11
08-21-2008 09:41 PM
pi75
Cobalt
7
07-16-2008 01:27 PM
SDFever
03-01-2007 11:46 PM
boatingbent
Nordic
109
10-26-2005 01:29 PM
26sonic
11-11-2004 08:49 PM
