What HeadGasket did Merc use on 575sci?
I looked up the Merc part number for an 02 575sci. It is a 27-811546A03 headgasket. Did they use Felpro or something else? I'm looking for the equivalent part # for what they used. Thanks.
Re: What HeadGasket did Merc use on 575sci?
The 575 uses a head gasket supplied by GM that's made by McCord. It is definitely inferior to the Felpro or Cometic's gasket. All 575's with stock gaskets should be replaced. The Fel-pro # you would need is 1047.
Use the Felpro and if it's a 02 replace them before you run the boat again. Save yourself a lot of trouble.
The Merc head gaskets are no good. |
Originally Posted by Quiet Storm
(Post 1550680)
I repeat, Cometic, Cometic, Cometic!
Best Regards, Ray at Raylar |
Originally Posted by Raylar
(Post 2426116)
Originally Posted by ciaoderhead
(Post 2426127)
Do you have a P/N?? Thanks
Cometic for the Mercury 525 C5760-040 x 2 x $96 each |
Originally Posted by cstraub
(Post 2426193)
Cometic Says:
Mercury Marine 525/625 Gen VI |
Originally Posted by zahndok
(Post 1550146)
| All times are GMT -5. The time now is 01:56 PM. |
