-   -   Gen VI,mark IV crank timing help please (https://www.offshoreonly.com/forums/general-q/118234-gen-vi-mark-iv-crank-timing-help-please.html)
fastlane40 12-11-2005 04:21 PM
I have a Gen VI 502 block and crane cam to suit.The stroker crank is a Mark IV with an adapter.My question is will i use a Mark IV flywheel and what timing chain setup will fit ?Anybody with a Gen VI timing cover for sale?Thanks for any help.
plumbers crack 12-11-2005 05:10 PM
Re: Gen VI,mark IV crank timing help please
If I am not mistaken,the gen 6 has a single row timing chain.When I built my motors I wanted a double row chain for reliability.I had to buy 2 custom covers from Scott shaffiroff racing in long island Ny.They were 1 piece billet with adjustable timing pointer.Around 200 bucks apiece.You must bring #1 piston to top dead center and realign timing pointer on the harmonic damper.My builder didnt and I ended up with a pile of scrap metal!Hope I answered the right question.You also will have different part numbers for crane cams gen 6 and gen 5.
rws 12-11-2005 07:40 PM
Yes, you would want to use a mark IV style flywheel,a gen 6 flywheel looks about the same ,but is balanced different because with the one piece rear seal there is not an external weight on the crank.A gen 6 stock timing cover only has enough room for a single row timing chain.Imco makes a cast alum piece that will clear a double roller chain.If you have a gen 6 style cam then you may be limited on chain choices.Look on cloyes web site .You can also find a stock stamped steel gen V timing cover this is the low buck alternitive.
http://www.cloyes.com/images/CloyesH...rmCat-2002.pdf
fastlane40 12-14-2005 06:02 AM
Thanks for the input guys.A Gen V timing cover won't fit because i have a gen VI block.Will the Gen VI timing chain and sprockets fit with a Mark IV crank?
Bubbletop409 12-14-2005 10:41 AM
I do not believe a Mark IV cam sprocket will match up with a Gen VI style cam. I know on the Crane site, different part numbers are listed for the same grind, depending on which gen. block you are working with.
Pat McPherson 12-14-2005 07:27 PM
If you bought a Gen VI roller cam with the turned down nose, you need a Gen VI timing set. The Gen VI crank gear should fit a Gen IV crank.
Use a Gen IV fly wheel; a Gen VI won't bolt onto a Gen IV crank.
asmith 12-15-2005 06:21 PM
scoggin dicky chevrolet sells a billit steel gen VI timing chain that is indestructable. they are curantly out of them. i am waiting for two my self. also a gen V flywheel wont fit on a mark IV crank the bolt flange is diffrent.
fountain333 12-16-2005 07:25 PM
there is only one good timing chain for the gen 6 engines and it is the rollmaster this is a great chain!! most manufactures just put there name on there chains or in cranes case they dont even put there name on it it still says rollmaster on the sproket !! they are a little spendy but worth the money and also have an 8 way crank sproket for cam shaft timing and from what i found all the keyways are exact to the tee!!! hope this helps !!
racinfever 12-16-2005 11:10 PM
comp cams makes a nice chain for your motor but you need to talkmore about your balance job, ihope your going neutral / internal balance with that flywheel ? :cool:
fastlane40 12-18-2005 02:30 PM
Okay guys so far i think i need to use a Mark IV flywheel and a Gen VI timing set and cover will work.Does that mean the balancer will also need to be Mark IV or are they all the same ?
racinfever 12-18-2005 06:24 PM
Is your engine going to be internally or externally balanced? All Gen 4, 5 and 6 flywheels and balancers are for external balance. With your stroker crank, I would think you would be going for internal balance. Which would mean replacing your
harmonic balancer and cutting all weight out of your flywheel for neutral balance. :rolleyes:
fastlane40 12-19-2005 04:05 AM
Is the balance associated with the crank?Do cranks come nuetral,internal or external balanced?If i use a Mark IV flywheel does that mean i use a Mark IV balancer or is this in relation to the crank?
racinfever 12-19-2005 12:04 PM
when replacing the crank shaft it is neccessary to rebalance. there are two methodes of balance, external & internal you & your engine shop should decide which is best for your parts combo & use . balancer & flywheel are different for each & never mix , external balance flywheels can be cut to neturel & used for internal balance motors.
