Leaking cylinders or trim pump. >
Old 12-13-2005 | 03:41 AM
ctadams21's Avatar
Default Leaking cylinders or trim pump.
I can't find the thread that explains this scenario but I know I read it somewhere.
I raised my drive all the way up, marked the fluid level of the trim reservoir, let it sit overnight. The drive bled down as usual and when I checked the fluid level, it did not appear to have moved.
Does this indicate bad cylinders or trim pump (check valve???)?
Thanks,
CTA
ctadams21 is offline
Old 12-15-2005 | 01:25 PM
ctadams21's Avatar
Default Re: Leaking cylinders or trim pump.
Never mind, I found it:
http://www.offshoreonly.com/forums/s...uid+level+trim
Old 12-15-2005 | 08:06 PM
Downtown42's Avatar
http://www.mercruiserparts.com/Show_...HYDRAULIC+PUMP
Downtown42 is offline
Old 12-27-2005 | 06:09 PM
ctadams21's Avatar
O.k. I took the big hex cap off of both sides of the trim pump and one of them was missing a spring to hold the check valve down. By the Mercury parts diagram these springs are not available separately. I also checked ebasicpower.com for aftermarket and could not find it. Are they available or do you have to hunt for used parts?
Old 12-29-2005 | 04:15 PM
ctadams21's Avatar
bump
jayhawk261
4
06-30-2007 07:58 PM
BillR
4
02-06-2007 03:23 PM
ratman
01-26-2006 07:48 PM
Dean Ferry
25
02-09-2005 06:32 AM
FA18Driver
3
01-27-2002 08:03 PM
