-   -   Boat Battery (https://www.offshoreonly.com/forums/general-q/119308-boat-battery.html)
Mikey Likes It 12-29-2005 10:57 AM
Boat Battery
Being that it is winter and I have nothing better to do but research what batteries I will use to replace my old ones with I came across the AGM, or Absorbed Glass Mat Batteries. Has anyone used these? In an article I read they stated that AGM batteries are as good as the Gel style batteries if not better. They cost about the same, but the thing that caught my eye was they offer them in the same physical size as my existing deep cycle battery which means I don't have to replace my battery box like you have to if you go to a Gel style. Please voice opinions.
Thanks,
Mike
Bill 3 01-19-2006 09:41 AM
Re: Boat Battery
I too am looking into batteries. Mine need replaced in the spring. I am not sure which to go with. Any info is great.
I do have questions if I go with gel batteries. Can I use my current battery charger/inverter? I have the impression that gel batteries need a special kind of charger.
Thanks,
Bill
Wobble 01-19-2006 09:53 AM
Re: Boat Battery
I run a pair of blue top optima's, 4 years old and seem to hold their charge very well. Cranks right up after 4 months storage and no charging. Run em in the race cars also. Don't think I will buy anything else for a while.
They will fit in most battery holders, but the ones designed for Optimas are a better fit.
floatingphil 01-19-2006 10:52 AM
Re: Boat Battery
http://www.offshoreonly.com/forums/s...d.php?t=112951
Check out this link, these are very lightweight if weight saving is important to you. If you go to the Odyssey website, they also offer nice boxes.
jpclear 01-19-2006 05:03 PM
Re: Boat Battery
Yep, The ODYSSEY battery is the way to go if you want to keep the boat for a few years without problems in that area. Not cheap, but worth every penny!! --- Jer
Outdrive1 01-19-2006 10:30 PM
Re: Boat Battery
I have Odessy's before, I have Optima's now, I don't think you can go wrong with either. The Optima blue tops are at Costco for about 150, nobody can touch that price, not even interstate dealers. Best thing about Costco is that they don't have a battery tester so you can get a refund every year and purchase new ones.
Bill 3 01-20-2006 07:06 AM
Re: Boat Battery
Thanks for all the input guys. Not sure if I want to afford the odessy battery, but I may look further into other AGM batteries.
Bill
Sonic30ss 01-21-2006 06:01 AM
Re: Boat Battery
I've been using the spiral batterys from NAPA. Not sure who builds them. I've had a set in my CTD Dodge for 4 1/2 years, and the still crank as good as new. I have one in my 68 Charger, in the trunk, I used to replace that battery every year due to sitting all winter(on trickle charger) and the vibration from drag racing, that one is 3 years old and can sit for months and still fire up a 12.5:1 Hemi no problem. I have two in the boat and have had no trouble in two seasons, lots of air time, lots of sitting with the radio on, and never any trouble starting. I've even killed them dead, recharged them and they are fine. You should read the mfg specs on recharging though, be sure you have the correct type of charger. Most new battery chargers will have a switch for lead-acid/AGM. I'm sold on these batterys.
Dave M 01-21-2006 08:45 AM
Re: Boat Battery
1 Attachment(s)
I use plain old Sears Diehards. For one reason is they happen to fit my battery box without the terminals touching the top metal part. They are $60, I replace them every 2 years. Never had a problem with them. My boat is subject to SEVERE poundings on a regular basis.
mrhorsepower1 01-21-2006 09:07 AM
Re: Boat Battery
I agree the Optima Blue Tops are my number one choice also. We have raced offshore with these batteries for years and they are very durable. Trouble free and they last!
Wobble 01-26-2006 09:46 AM
Re: Boat Battery
Correction :D
I took my load tester and checked out my batteries on the boat this week. One blue top has died, 3 years and eleven months old. Replacement was $149 at autozone. Blue top 34MD.
madbouyz 01-26-2006 11:36 AM
Re: Boat Battery
I once heard (from someone who's opinion I value) that today's EFI engines don't like gel batteries for some reason.
IS there any truth in this ? ?
Wobble 01-26-2006 11:48 AM
Re: Boat Battery
None that I know of. Check out any race car, AGM or GEL batteries. EFI or Carb
Bill 3 01-26-2006 11:51 AM
Re: Boat Battery
I have never heard anything like that, unless it has to do with the charging systems. Gel and AGM batteries can be ruined by overcharging, or at least by charging with too high of voltage. At least that is what I am learning.
I think :rolleyes:
madbouyz 01-26-2006 11:59 AM
Re: Boat Battery
I think :rolleyes:
Actually .. that sounds more like what I recall hearing .
That's a bit more understandable huh ?
jpclear 01-26-2006 05:57 PM
Re: Boat Battery
The Odyssey battery cannot be hurt by "fast or overcharging". But charging them with voltages in excess of 15 volts may cause some "gassing" and damage to the sealed structure. BTW, These are the premium batteries that Teague has put his name on to market. So, regardless of what that's worth in your opinion, it's still a great product! --- Jer
Mikey Likes It 01-26-2006 10:23 PM
Re: Boat Battery
Here is a great link I found that explains a lot about batteries.
http://www.windsun.com/Batteries/Bat...at%20Batteries
I have chose to go with the Trojan AGM Group 27. This Battery fits right in my battery box and have been told that it is not as susceptible to over charging like the Optima Battery.
Poorsche 01-27-2006 06:59 AM
Re: Boat Battery
The TROJAN batteries are bullet-proof and cost 1/3 price of Optima and Odyssey. I had Optima's and the ratings are way overstated--Optimas struggled to crank my BB EFI 454's. The Trojans ratings are understated -- best buy for the money IMHO.
Mike Paula 01-27-2006 07:26 AM
Re: Boat Battery
Amen! I run ACDelcos for the same reson. My Main starting battery will be replaced this season ( been in for 3 yrs) and My back up will stay, and at about $60.00 I will save about $100.00 for more gas money.
