Look At The Size Of This Thing !
Old 09-22-2005 | 06:33 PM
teaguecustommarine's Avatar
Offshoreonly Advertiser
Talking Look At The Size Of This Thing !
NEED ROOM? NEED TO LOOSE WHIGHT?
you havent seen anything like this
920 cranking amps for 5 seconds
870 cranking amps fpr 10 seconds
765 cranking amps or 20 seconds
and if your cranking for more than 20 you got problems.
Short circuit current over 2400A
28 amp hours
50 minute reserve capacity with 25amp load
Female brass terminal w/M6 SS bolt
Length 6 15/32"
Width 6 7/8"
Height 4 7/8"
Weighs 23 lbs
3 year full warranty
Rugged Drycell sealed design
Vibration resistant
60% more starting power
Deep discharge reserve power
2 year storage life
8-12 year design life
AND ITS ONLY $149.98
call me and i will ship out same day
teaguecustommarine is offline
Old 09-22-2005 | 08:00 PM
Default there are billet mounts for this battery
take a look at our classifieds to see the billet mounts for this battery.
Old 09-23-2005 | 03:58 PM
Default other styles and sizes
we can also get these in other sizes
from 1200CA - 1700CA - 2150CA
Sterio systems..... NO PROBLEM !
Old 09-24-2005 | 01:52 PM
DanB's Avatar
Charter Member #71
Default Re: Look At The Size Of This Thing !
Are these deep cycle?
Who makes them?
Prices on 1200-2150 and dimensions please
DanB is offline
Old 09-24-2005 | 02:18 PM
yeah info have big stereo want more juice thanks
kickin32 is offline
Old 09-27-2005 | 11:03 AM
Default 1200-ca $178.60
1200 cranking amps for 5 seconds--------------------------------
1090 cranking amps for 10 seconds-------------------------------
900 cranking amps for 20 seconds--------------------------------
Short circuit current over 2600A-----------------------------------
44 amp hours--------------------------------------------------------
78 minute reserve capacity with 25amp load-- ------------------
With SAE automotive terminals------------------------------------
No metal jacket-- ---------------------------------------------------
Length 7 11/16"-----------------------------------------------------
Width 6.5"-----------------------------------------------------------
Height 7.5" including the terminals-- -----------------------------
Weighs 38.2 lbs-----------------------------------------------------
And for the ones that need a little extra cranking power this one is probably the one to step into. Along with the 1700CA or the 2150CA you would have yourself a pretty nice dual battery system
Old 09-27-2005 | 11:10 AM
Default 1700-ca $245.10
1700 cranking amps for 5 seconds -------------------------------
1540 cranking amps for 10 seconds ------------------------------
1355 cranking amps for 20 seconds -----------------------------
Short circuit current over 3500A ---------------------------------
68 amp hours ------------------------------------------------------
142 minute reserve capacity with 25amp load-------------------
With SAE automotive terminals -----------------------------------
Length 13.0" --------------------------------------------------------
Width 6.5" ----------------------------------------------------------
Height 7.5" including terminals -----------------------------------
Weighs 59 lbs ------------------------------------------------------
this battery is probably what i would use if i had the BAD MAMMA JAMMA sterio system
Old 09-27-2005 | 11:12 AM
Default The Mac Daddy 2150-ca $298.97
2150 cranking amps for 5 seconds -------------------------------
1985 cranking amps for 10 seconds -----------------------------
1695 cranking amps for 20 seconds -----------------------------
Short circuit current over 5000A ---------------------------------
100 amp hours ----------------------------------------------------
200 minute reserve capacity with 25amp load ------------------
3/8 in. (9.5 mm) corrosion-free stud terminal ------------------
Width 6.80" --------------------------------------------------------
Height 9.40" -------------------------------------------------------
Weighs 75 lbs ------------------------------------------------------
*FOUR YEAR WARRANTY*
2150-CA is a Group 31-size deep cycle. lasts up to 10 years in engine-start operation versus 2-3 years as compared to similar batteries. provides greater cranking power
this would be a fantastic battery for large sterio systems
Old 09-27-2005 | 11:50 AM
Firewalker
These are the best batterys on earth, we have been using them on our outboard drag boats for years!. ( four you slow boat guys, our race motors have little charging or total loss ignition, and these are the only ones that stand up, they also are very resilient to viberation, and can be mounted in any direction. )
GREAT Price, I am assuming that is the 1200.
RT
Old 09-27-2005 | 04:42 PM
they are not just a great battery for your charging system but they are great looking and small. I saw the 925's in the new Lavey Craft race boat a couple weeks ago and they took up little to no room, heck i almost didnt even notice them but when i did OHH YEA BABY. these batteries are just cool
