-   -   150 ci ... 720 hp (https://www.offshoreonly.com/forums/general-q/119329-150-ci-720-hp.html)
stevesxm 12-29-2005 03:56 PM
150 ci ... 720 hp
was just reading where the new F1 motors are about 150 ci (2.4l) v-8 and the first generation ones are making 720 hp on 101 octane fuel..... normally aspirated.... and they only weigh about 200lbs i think..... so 4 of those for every 502....
wow... that would get you across the water...
cmcnitt 12-29-2005 05:59 PM
Re: 150 ci ... 720 hp
the only problem is that with only about 250 lbft of torque, you'd want to hit the water at top speed, and don't stop (kinda like the snowmobiles)!
Wobble 12-29-2005 07:15 PM
I hear they are expecting to reach 800hp by mid season!
stevesxm 12-30-2005 07:09 AM
at what... about 19,500 revs this year ? geeze... remember when 500 cc 2 cycle bikes couldn't do that ? imagine putting that technology and materials in a 500 inch v8....
would make 700 hp at idle...which would be about 8000 rpm...
have to have some VERY good transmissions and drives... and would be well w/ in everyone's budget at about 2.5 mil each
oh well back to my iron v-8's
happy new year everybody
JCPERF 12-30-2005 08:25 AM
It idles at 7000 RPM
Big Block Billy 12-30-2005 10:06 AM
Is it a 2 cycle ? If it is it's like having 300ci from the get go. when you compare it against a 4cycle motor. If I could figure out a way to get water from the bottom of the boat through a strainer on the boat bottom and then through a strainer in the boat I'd be real interested in outboards. Out here on the south shore of Long Island , we have a huge seaweed problem,(maybe because of everyone fertilizing their lawns) also more shallow water than deep water in the bay. I think the deepest it gets is about 12 ft. Anyone have any ideas ? Also you won't suck up a plastic bag on a wedge strainer like you will with it wrapped around the lower unit. And the outboard get's its water from the bottom of the lower, the first thing to hit bottom. With the wedge strainer even if i hit bottom, I'm still getting good water, instead of sand and muck. Alot of us have boat slips and canals that are shallow and the officials won't dredge, something to do with Epa, Army corp. of engineers, etc... mostly $$$. So we are forced to drive our boats through crap. BBB :(
stevesxm 12-30-2005 03:35 PM
no...4 cycle , 8 cyl , 2.4 l, 4 cam 4 valve pnuematic valve train
efi, normally apirated....
monstaaa 01-03-2006 06:31 PM
Where Is This, I'd Like To See?
rmbuilder 01-03-2006 06:41 PM
Monstaaa,
They could only get this one to idle down to 9000!
http://www.cosworth.com/downloads/co...d91fe7d1f82e25
Bob
monstaaa 01-03-2006 07:05 PM
T.y Bob, Checked It Out, Sounds Painful. Any Actual Pics Of It.
