-   -   Revolution Marine Exhaust (https://www.offshoreonly.com/forums/general-q/119661-revolution-marine-exhaust.html)
DORaymond 01-04-2006 06:23 AM
Can anyone tell me there experiences with Revolution Marines BB Performance Exhaust? Appears to be a good value at under $1000 a pair.
Payton 01-04-2006 06:50 AM
Re: Revolution Marine Exhaust
Do a search here in the tech section. They have been discussed a few times. Most seem to agree, they are a good deel.
BajaIceBreaker 01-04-2006 07:17 AM
I bought a set last summer, but I also did a rebuild, so I can't give you definate performance gains, however, I can give you my opinion.
1) I like the design. Taller than stock, and better flow/separation.
2) Dollar for dollar, I don't think they can be beat.
3) Everyone that has talked about them has complained that the holes have too much powder coating on them and they had to be cleaned out with a 1/2 pipe tap. Not a big deal though.
4) Very light wight.. number one reason to buy.
5) Easy install. Allmost everything I needed, brackets, bolts, etc., were included.
6) Good people to work with. Fast responses, quick delivery, etc.
7) I think minimal performance gaines over stock exhaust.
Monkey Spanker 01-04-2006 10:22 AM
They are virtually identical to the IMCO thumper, which I put on mine. With either set you will find that the power steering pump will hit them. You will need the relocation bracket with either set. I picked up 150 rpm and 1.5 mph with my IMCO's. Also the exaust was suprisingly quieter, did not have the sharp pop,pop,pop from the cam. Was more of a deeper rumble. Bear in mind my motor is a 496 putting out 521 hp at the crank. :chimp:
Too Old 01-04-2006 09:50 PM
We've been selling them for a short time. Everyone who has purchased has been satisfied.
http://www.trickmarine.net/productde...?productid=777
vandeano 01-05-2006 05:27 AM
I put some on my 502 mag. Only real problem was the install. The angle to the transom was different then the stock set up, which kind of made it difficult at first to install. Other then that I have had mine for over a year and run in salt water every weekend and they seem to be fine. I wish they could be a little louder. Didn't really seem to notice any more hp, but then again I did a rebuild at the same time. All and all Im satisfied. :drink:
PS...Customer service was great. The guy at Revolution marine was a great help with my angle problem. Very patient. :drink: :drink:
DORaymond 01-05-2006 04:24 PM
Vandeano,
So just to be clear, the Revolution exhaust exits at a different angle than stock Mercruiser exhaust? Did your stock exhaust use spacer blocks?
Monkey Spanker 01-05-2006 10:20 PM
It exits at a different angle because it is about 3-4 inches higher at the riser. I could not reuse my silent choice either because they are too short and would not fit over the riser outlet. I had to use a set of Corsa quick and quiet "Y's" to replace the diverters. Even then I could only get enough to get one of the two hose clamps on. If your exaust goes straight out the transom, it should be workable. :chimp:
vandeano 01-06-2006 02:58 AM
Originally Posted by DORaymond
Vandeano,
My factory exhaust didn't have spacers. If you were to put the factory exhaust next to the revolutions you would probably say there is no way this is going to work. I was getting ready to send mine back until the guy at revolution told me the trick way of doing it. (he would be better to explain it then me). But it worked. I just had to make the rubber exhaust hose where it connects to the tips that exit the boat shorter. I was able to still use my Silent choice. My problem was just with how steep my angle was.
epeek 01-06-2006 09:26 PM
I used them on my 32 Fountain 502's. The worked great,but were
a bitc h to install. silent choice and the different angle made it
tough to install exhaust hoses. Once on,they performed flawlessly.
They are good guys to work with if you have questions.
P.s. Its true about powdercoat in threads,they do need to have a tap run thru to clean them out.
32storm 01-08-2006 09:14 AM
epeek......Did you see any kind of increased performance on the Fountain with them?
epeek 01-09-2006 09:21 PM
I labbed the props at the same time. Picked up 2 mph
but don't know from what,the props or exhaust,or both.
They sound good though.
pullmytrigger 01-09-2006 09:33 PM
epeek......did your azz end come up at all....??
32storm 01-11-2006 07:15 AM
May have picked up 1-2 just with the labbed props. Still kicking these around for replacing stock, as well as Stainless Marine, EMI, & Imco.
pullmytrigger 01-11-2006 10:00 AM
I'll give them credit.......at least they'll publish their dyno tests......hard to know from our end if their legit but other than CMI I know of none other that has done that.......doug
got mine in the mail the other day 2 sets smallblock, fully polished.....I'll post some pics in a day or so
