Programmable knock control systems >
Old 11-13-2007 | 06:43 AM
  #71
Doesn't post #63 above say that it works with both types of sensor?
Ruaraidh is offline
Old 11-13-2007 | 08:50 AM
  #72
Rage's Avatar
Yes, but no explaination has been forthcoming as to how so until then................
Rage is offline
Old 11-13-2007 | 11:12 AM
  #73
Friend of mine used to run one of these on an F3 car. I'll do some digging if you like.
Ruaraidh is offline
Old 11-13-2007 | 03:02 PM
  #74
Rage's Avatar
Sure if you don't mind. Not a high priority item. Just trying to learn more about these different knock warning / sensing systems.
Rage is offline
Old 11-14-2007 | 12:18 PM
  #75
Older units are factory set. Newer ones are adjustable.
Ruaraidh is offline
Old 11-14-2007 | 10:14 PM
  #76
RW? I read your last email, but it didn't click that you knew Ian.
Rage: I haven't responded, since the processors we were using are now very hard to get, though I have a contact in Asia that says they are still available.
Ian Whiteside is a calibration engineer at Ilmor Racing in the UK. He bought a system for his personal Formula 3 race car maybe three years ago. The engine is 2.0L, based on a 1.8L Eclipse engine, with 14:1 compression.
He said that with that much compression, the engine is severly knock limited, and can run no more than about 14° timing at 4000 RPM, with 98 RON fuel.
A MoTeC M400 was installed and adjusted on the dyno. Timing was optimized using knock sensing headphones, then was retarded two degrees as a safety margin.
The J&S was then installed, and timing was bumped two, four, then six degrees. The dyno operator could detect nothing more than occasional trace knock, yet the J&S was controlling timing on the knocking cylinders.
Remember, when you adjust for no knock, you are tuning to the worst cylinder, sacrificing power in the others.
Individual cylinder knock retard increases engine efficiency and power. Ian emailed that he was showing a four percent gain. Didn't sound like much to me, so I didn't bother plotting his spread sheet data for about a year. I was amazed to see the area under the curve when I did. The graph shows an eight percent gain when they switched to 102 RON, the spec fuel for his series. No other adjustments were made.
When you get to my site, click on the Vampire link, then scroll down to the dyno graph.
John at J&S is offline
Old 11-15-2007 | 05:42 AM
  #77
Yep, Ian and I both used to work together at Cosworth and then Integral before he went on to Ilmor.
Individual knock control really is the correct way to go. Certainly calibrating Bosch systems when compared to the old method of open loop spark calibrated to worst pot and then retard 3 degrees, the ability of a proper multi channel knock control system to optimise every cylinder yields significant performance advantages.
I'm sure that with in vee intercooled pre SC carbed V8s ie likelihood of significant AFR changes from cylinder to cylinder down the blower, that a proper knock control system would give a major boost, as well as piece of mind.
I'll have to dig out some in-cylinder pressure traces and FFTs for everyone's amusement at this rate.
I'll get back to you separately on that sprint car question John.
Ruaraidh is offline
Old 11-15-2007 | 10:13 AM
  #78
Rage's Avatar
John, I guess back to my original question "What is involved to configure a J&S unit to work with the pair of Mercruiser "non-resonant frequency" knock sensors versus a single frequency tuned knock sensor?" May I assume from your comment below that the addition of a special (hard to get) processor to your basic J&S unit is required so that it will work with "non-resonant frequency" knock sensors? Would there be additional custom programing to taylor this additional processor to properly work with my unique engine or does adding the additional special processor alone produce a turnkey unit that will work properly with all "non-resonant frequency" knock sensors without any addition custom programing?
Thanks,
Bill
Rage is offline
Old 11-15-2007 | 11:03 AM
  #79
No, I think he's saying that the processor he uses is hard to get full stop. Irrespective of input type.
The main difference between the input stage for resonant and non- resonant is the level. Just turn the gain up. That's all there is to it.
Ruaraidh is offline
Old 11-15-2007 | 01:29 PM
  #80
Rage's Avatar
Really. I have the general specs on my Delphi knock sensors, copy attached, but have no idea what the resonant knock sensor output versus engine vibration specification is. I am getting the impression that the resonant sensor output is low (filtered) until the "tuned resonant frequency" is reached by at which point the sensor output signal amplitude increases significantly, like a step function, and then returns to a low amplitude above the "tuned resonant frequency". Is that how it works or other?
File Type: pdf
Rage is offline
