The Truth about steps? >
Old 01-10-2006 | 08:34 PM
Hydrocruiser's Avatar
Arrow Re: The Truth about steps?
Originally Posted by audacity
hydro...again modern day boats are not only better going straight line, they turn WAY better than older conventional hulls too.
hydro, you got ejected at 95mph! wow most would not be alive....what boat was this? how much damage was done?
I think I half jumped out as he made a fast turn..like ditching a motorcycle...so it was controlled to a degree...I was shaken up but a good ski type jacket helped...lots of air time for me...mangled the drives..driver bruised....promised not to name the brand..it was his driving...but it was stepped...and partially spun out..never go out with show offs...
Hydrocruiser is offline
Old 01-10-2006 | 08:45 PM
ZXXX Donzi's Avatar
Default Re: The Truth about steps?
3-5 mph vs a percentage? If it is a percentage then the advantage increases as the speed increases. I think that is part of the question.
You also have to consider that a step hull can run a higher x-dimension since some bow lift is generated by the hull in a step. Although blow-out and other things come into play, you can reduce parasitic drag from the lower unit. That should also come into play. How much? That is also part of the question. I am guessing an additional 3 mph.
As far as the pad. It is definately more efficient than the full V. But you do have a nice flat pad for landings as well. On good water it is great. I ran some stuff on Sunday that would have been no fun on a pad. My big heavy V stomped it.
ZXXX Donzi is offline
Old 01-11-2006 | 03:32 PM
The truth about steps is that they are here to stay..
Old 01-11-2006 | 03:43 PM
BLee's Avatar
Charter Mod
Originally Posted by Hydrocruiser
last summer going 95mph with a friend I learned how to swim in a hurry...he took a turn a bit too fast
95mph into a turn? You're lucky to be alive, and have no idea what you're doing. Sorry Hydro, but you guys are part of the problem if you're out there doing that.
BLee is offline
Old 01-11-2006 | 04:28 PM
jmackin's Avatar
I am wondering how a 42 outerlimits w/ 850's can run 118mph and a 42x cig w/ 850's can barely reach 100mph? The outerlimits even has a complete cabin. I think I would take the cig anyways but that is a huge difference!
jmackin is offline
Old 01-13-2006 | 07:15 AM
BajaIceBreaker's Avatar
Originally Posted by JS232
Uhh? A Baja with a Pad??? Maybe they did in the vintage Hulls? Are We talking about the same thing?
Have a look:
Yeah, we are talking the same thing...
BajaIceBreaker is offline
Old 01-29-2006 | 10:51 AM
my step 38 502 Powerquest runs almost exactly as fast as a non-stpe PQ with 500s. Its so close you cant measuer it.
powerquest 380 is offline
mcraymond3
Outerlimits
11
11-08-2006 07:43 PM
ActiveFun
Fountain
11
12-20-2005 09:11 AM
bradfitz
Fountain
10
06-02-2005 07:10 AM
PhantomChaos
03-29-2005 09:36 AM
