Weight of SBC vs BBC
I'm very curious of the weight difference between the small block and the big block. We are thinking of repowering the'86 28 Cig with small blocks instead of big blocks. The boat seems a little azz heavy. Or could the savings be had with aluminum intake, manifolds, and heads? Yes, it has TRS. Currently, in the water, off plane, the water line at the transom is within an inch of the rub rail.
I'm not sure if this boat came from the factory with big blocks. I've been told that the 28 Cig runs the best with small blocks because of the weight.
Your Help is Greatly Appreciated!
Big Andy
Big Andy
I remember reading a MerCruiser spec. sheet and I think it said the big block package was 228 lbs. more than the small block.
I have driven the 28' Cigarette many times and it's a much better boat with the small blocks. It felt too tail-heavy with the 454s.
There was a 28' with a pair of very healthy Lingenfelter small blocks and TRS that was the best down here. Somebody bought it and I never see it anymore.
Yes, Some did come from the factory with the big blocks. I would go with the all aluminum stuff if you are in fresh water. If you are in salt I would go with some FWC 320hp 377 or somthing similar. Or better yet add alum exhausts to the Small Blocks.
I had a 1978 28' Cig with 280TRS engine and drives. That boat sat vary low even with the small blocks...
With out question the boat handles better with small blocks too.
I agree with Ironman, stroker smallblocks is the best way to go. And even then try to lighten them up with aluminum exhaust and maybe even aluminum heads...
Have fun! you have a great old classic!
Patrick
Patrick
Have you looked into A Dart block. I know you can put some serious stroker kits in the SB Chevy. A friend has a 434 & its indestructible, & they can take some serious HP also.
Thank-You for all the helpful info! I will most likely go with stroker small blocks. Reason being...I want the TRS's to last at least another season. After this season, I will probably switch the drives to Bravos. I'm also curious about the Center of Gravity when I convert to Bravos. Should the engines remain in the same location with a short driveshaft or should the engines slide aft, where Bravos are normally mounted?
Big Andy
Big Andy
Big Andy
Big Andy
